Old 12-27-2008, 10:16 PM   #1
texastrendz
sway bar
who makes the best sway bar for the money? my truck currently does not have one. i am confused because some manufacturers say they fit some trucks and others not, can anyone give my any insight on why this is. thanks guy and gals as always.
texastrendz is offline   Reply With Quote
Old 12-27-2008, 11:23 PM   #2
1968SWBBigBlock
Active Member
1968SWBBigBlock's Avatar
Re: sway bar
ECE has a nice unit - call Mark -- He has installed theirs on his daily driver with a 3/5 drop
1968 SWB
454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts
781 heads Ported with 2.19/1.88 SSTvalves
Lunati 60204 cam, Micro Trol lifters,
Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition
Holley 770 Street Avenger carb,Headers armor coated
Built by Watson Ruppel Performance in Sarahsville Ohio.
Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall
12 Bolt Eaton Posi 4.10 Richmond Gears moser axles
18.5" x 31" Hoosier Pro Street Radials
ET Classic 5 Wheels - polished
Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone)
Custom Paint & Body Work
Special thanks to my wife, my son and my money tree
1968SWBBigBlock is offline   Reply With Quote
Old 12-27-2008, 11:37 PM   #3
71swb4x4
71swb4x4's Avatar
Re: sway bar
What year truck? 1/2 ton? pickup?
Best bang for the buck - GM. Go to a junkyard. Around here I can buy sway bars with brackets for $25.
Some people are like slinkies, they aren't good for anything, but you can't help but smile when you see one tumble down the stairs.
71swb4x4 is offline   Reply With Quote
Old 12-28-2008, 07:38 AM   #4
Mr79C10
It Is What It Is,,,,
Mr79C10's Avatar
Re: sway bar
So true!!
or less? ya never know
*79 C10 Short Box ST8 6 bang'r *
*Lowered w/ 3" Control arms, 2" Lower Coils and 4" shackles and hangers W/ FLIP KIT
*__--__*
79 C-10 project
.........................__
..............._____ l __\___
..............|_(O)_ |___(O) ]
FAQ INDEX Thread
The Kulture
My Rat Den
Mr79C10 is offline   Reply With Quote
Old 12-28-2008, 01:43 AM   #5
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: sway bar
71swb4x4 is correct. You can't go wrong with a GM bar. Check your local salvage yard and get them cheap. Most Burbs had them or you kind find a 1-1/8" unit under a 3/4 ton truck.
Articles-
"Jake" the 84 to 74 crewcab
"Elwood" the77_Remix
85 GMC Sierra "Scarlett"
"Refining Sierra"
Old 12-28-2008, 12:45 PM   #6
texastrendz
Re: sway bar
does it matter on the years. mine is a 72 with factory lower arms. will a 73 and up fit or not. just want to know what i am looking for a the salvage yards. thanks for all the help.
Old 12-28-2008, 03:33 PM   #7
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: sway bar
Originally Posted by texastrendz View Post
does it matter on the years. mine is a 72 with factory lower arms. will a 73 and up fit or not.....
Ooops, didn't notice that you were asking about pre-73. I "think" the later bars will work, but lets let one of the 67-72 experts verify my thoughts.
Shane- If your talking about 73-87 bars the smaller bars are 1" and the larger bars are 1-1/8"
Articles-
"Refining Sierra"
Old 12-28-2008, 10:33 PM   #8
ERASER5
ERASER5's Avatar
Re: sway bar
Yes the '73-'87 bars fit perfectly with factory ride height. If you have a lot of drop, or bags, you may have to cut 3/4"off of the ends.
'70 GMC C1500 LWB
Power disc brakes. WooHoo!
Posi 6 Lug Dana 60
ERASER5 is offline   Reply With Quote
Old 12-28-2008, 10:39 PM   #9
leftcoast66
leftcoast66's Avatar
Re: sway bar
Why 3/4"? Just wondering, never heard of doing that. I understand the whole preload idea with the bars, but wouldn't it just depend on the amount of the drop for how much you would cut it?
leftcoast66 is offline   Reply With Quote
Old 12-28-2008, 01:56 PM   #10
smashingchuck
It'd be alot cooler if you did
smashingchuck's Avatar
Re: sway bar
I like the one I picked up from BellTech. Not exactly cheap compared to junk yarding one though.
78 Build Thread
4Runner Build
smashingchuck is offline   Reply With Quote
Old 12-28-2008, 02:45 PM   #11
Shane
Shane's Avatar
Re: sway bar
If you go junkyarding, get one from under a 3/4 to 1 ton truck ... they are larger diameter (1.250" diameter- ?? maybe- not 100% sure) and are usually the same money as the 1/2 ton (1.125" diameter).
Shane is offline   Reply With Quote
Old 12-29-2008, 03:23 AM   #12
Frizzle Fry
Frizzle Fry's Avatar
Re: sway bar
I had to cut about that off mine when i bagged it. #1 the bags have a larger diameter than the springs and #2 when dropped the bar pushes through the arm bushing more (frame side being fixed fore/aft). Mine's a 73-87 bar on a 72 front susp FWIW.
Frizzle Fry is offline   Reply With Quote
Old 01-01-2009, 07:10 PM   #13
leftcoast66
Re: sway bar
Gotcha, thanks. For some reason mentally I was thinking about the mount, not the bar itself. Hadn't thought about the bar pushing in at drop though, thanks.
Old 12-29-2008, 09:30 AM   #14
72BlckButy
Tot Roddin'
72BlckButy's Avatar
Re: sway bar
Most people have mentioned junkyards, but you also can't forget the parts board on this site.
-Nate
1969 CST SWB - Project Blank Slate (4.5/6" ECE Static Drop, 6-lug disc brake upgrade (manual), Billet Specialties Vintec 20x8.5 255/40 (F) 20x10 295/40 (R), 250 I-6)
1960 AMF Skylark - Tot Roddin' (Lowered with custom frame; soon to include custom push bar and interior)
2008 Silverado CrewCab 1LT (5.3L, 3:73, 4x4, LT1, Z-71, Towing Package)
72BlckButy is offline   Reply With Quote
Old 01-01-2009, 01:53 PM   #15
sick69
sick69's Avatar
Re: sway bar
I pulled an 1 1/4" front sway bar off of a 74 3/4 ton 2wd and it bolted right up to my 70 2wd. Not problems at all.
As for cutting the sway bar when dropping a truck,,,,,,I dunno yet. I will be doing the frame and suspension late Jan/early Feb so I'll see.
Frank
70 chevy lwb c10
454/th400 and a 9" rearend
suicide doors, marker light fuel fill, 4" cowl , mini tub
sick69 is offline   Reply With Quote
Old 01-01-2009, 02:45 PM   #16
spr85gmc
spr85gmc's Avatar
Re: sway bar
what about a rear sway bar where can i find one of those
spr85gmc is offline   Reply With Quote
Old 01-01-2009, 06:26 PM   #17
N2TRUX
Happy to be here
N2TRUX's Avatar
Re: sway bar
Lots of Burbs had them as well as some 3/4 tons
Articles-
"Refining Sierra"
Old 01-01-2009, 06:29 PM   #18
trenz68
Damage Inc
trenz68's Avatar
Re: sway bar
I ordered my sway bar on LMC truck. Has just about everything you need. Paid about 150 for the sway bar and 30 for the brackets. Junkyard would be the cheapest way to go.
trenz68 is offline   Reply With Quote
