12-28-2008, 09:39 AM | #1 |
Is it any good rockwell transfer case
I just traded for a 72 long bed truck that I was told is sitting on a73 4x4 frame. Pulled body off frame found transfer case to be a rockwell. I`ve never had no dealings with one always had new process. Is rockwell any count or do I have a hunk of scrap iron.
12-28-2008, 12:46 PM | #2 |
SKINNY TIRES RULE!
Re: Is it any good rockwell transfer case
The Rockwell 221 is a solid transfercase, but not as nice as sturdy as an NP205. For normal use, you shouldn't have a problem. If you're going to be doing some rock crawling, you may want to look for something else.
As far as I know, a 73 truck shouldn't have had a Rockwell. I should be either a NP205 or a NP203. Many of the rockwell cases had PTO capabilities, so that is a plus if you're going to use the truck as a work truck. A buddy of mine rebuilt the rockwell in his 66 3/4 ton. He found the kit on the web and found a parts case at the swap meet for $50.
bouncytruck 1972 K5 The Hauler 1994 K1500 Suburban The Daily2010 Kia Soul Wife's Ride2014 Fiat 500L |
12-28-2008, 08:05 PM | #3 |
Thanks for the info,I really wonder about the running gear on this frame was told it was a73 chevy but don`t know for sure.I thougt it should have a new process instead of the rockwell. It also has a funny rear diff. it has an inspection cover but the chuck loads from the front its 3/4 ton but I haven`t ever seen this on a GM.
12-28-2008, 10:14 PM | #4 |
The rear is an Eaton ho52 I believe,looks like a big 9inch Ford,but with 8 lug wheels.
12-29-2008, 08:28 AM | #5 |
What you are describing, with a Rockwell and the corporate H052 is a 1967 or '68 chassis at the newest. Is the Rockwell married to a 465, or is the tranny a 420 with a divorced Rockwell?
Tim |
12-29-2008, 09:03 AM | #6 |
Its hooked to a 4 speed its not divorced,also the rear end sorta does look like 9 inch ford. Sound like I gotta bunch of scrap iron. But thats how my luck goes, fall in a pile come out smelling like the pile.
12-29-2008, 10:42 PM | #7 |
Could be a 69 also, that's the combo that was in my 69 K20
1970 Blazer with a 400 sbc and 4" lift 1980 Pontiac Trans Am, 455 Oldsmobile 2012 Kawasaki Concours 14 |
12-30-2008, 08:14 AM | #8 |
Is there any numbers on the frame so I can find out what year it is. If it where 67,68,69 frame the 72 body I pulled off should have lined up with all the body mounts and it diddn`t .The rear cab mounts on the frame were a good 6 inches away from the 72 rear cab mount bolt holes.
12-30-2008, 11:51 AM | #9 |
The numbers on the frame are just part of the vin #, but if my memory serves me, it will give enought to find the year. The numbers are on the drivers side top of the frame a little behind the steering box location.
12-30-2008, 07:53 PM | #10 |
Thanks i`ll check it out. Thinking about posting the 72 body in the parts for sale . It is pretty good body haven't found any rust in it and its got descent paint. Its got a big hole in center of cab floor where it was on 4 speed frame and thats all I wanted was the running gear.
