12-28-2008, 09:52 PM | #1 |
front sway bar
should i keep my front sway bar on or not? I think that it might help with traction and frame twisting, but i'm trying to eliminate front end weight.
http://67-72chevytrucks.com/vboard/s...d.php?t=494388 431 big block times, changed to a 6.0 ls with turbo 1.58- 60' 7.18- 1/8th mile@95.18 11.37- 1/4 @115.81 |
12-28-2008, 11:01 PM | #2 |
Re: front sway bar
if all you do is go straight, sure... chunk it.
01-05-2009, 08:55 AM | #3 |
Re: front sway bar
not counting the weight I bet if you just unhook it from the control arms it will help your weight transfer. It depends how much you drive it on the street but it should be a little faster on the track without it.
Kevin Special Thanks to All who have helped on the TRUCK! My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4 So Far my best Times are: Motor only: 6.44 1/8 @ 104.13 10.39 1/4 @ 125.83 Nitrous Times: 5.785 1/8 @ 118.65 with a 1.336 60ft 9.168 1/4 @ 142.58 with a 250 shot dead out of the hole! |
