Old 12-29-2008, 03:58 PM   #1
SixtySixC10
Front crossmember...
What year front crossmember will bolt into my 1966 so I will have 5 lug and disc brakes?
SixtySixC10 is offline   Reply With Quote
Old 12-29-2008, 04:50 PM   #2
scotts62
One day...
scotts62's Avatar
Re: Front crossmember...
73-87 just have to drill a couple holes in frame.
Scott
93 crew cab build
Project 62
Old 12-29-2008, 05:00 PM   #3
SixtySixC10
What would you reccommend I do about the back?
Old 12-29-2008, 05:04 PM   #4
scotts62
One day...
scotts62's Avatar
Depends on your plans, i was planning on bagging mine anyways so i found a different rearend, i have a ford 9 with disc brakes from a lincoln versi. You could find a 12 bolt and buy the conversion kit to bolt up to the trailing arms. That would save from buying axles or having them drilled.
Scott
93 crew cab build
Project 62
Old 12-29-2008, 06:10 PM   #5
SCOTI
SCOTI's Avatar
Replacement axles/drums in a 5-lug pattern. Check out ECE, GMC Pauls, or Classic Hearbeat for conversion stuff (kits). I used Moser axles for my 6-lug 68 rear end & then swapped to 71-72 5-lug drums w/o any problems.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
SCOTI is online now   Reply With Quote
