Old 12-29-2008, 07:25 PM   #1
royo
royo's Avatar
? for dropmember guys
yes i,ve seached. does anyone have pics of there braklines on the front after the dropmember installed thanks
nickle and dime
royo is offline   Reply With Quote
Old 12-29-2008, 10:18 PM   #2
mycool72
mycool72's Avatar
Re: ? for dropmember guys
Have you searched? HAHA j/k I'm sure someone will chime in here. I don't have anything on the subject.....
mycool72 is offline   Reply With Quote
Old 12-29-2008, 10:36 PM   #3
lolife99
67-72 parts collector,…
lolife99's Avatar
I would imagine you're going to have to bend them up yourself. I don't think anything stock will work.
Keith
Convert to disc brakes.
Old 12-30-2008, 12:03 AM   #4
rddiaz
rddiaz's Avatar
hey royo, I'll post some pics 2 morrow, it's kinda late, but if I remember right I didn't have to replace any lines just had to push and pull some.......
GROUND ZERO IS R LIMIT
rddiaz is offline   Reply With Quote
Old 12-30-2008, 01:09 AM   #5
PBFAB.COM
PBFAB.COM's Avatar
I have bent them up a couple ways:
I have ran them across the Dropmember just like on a factory 63-72 crossmember set-up... and I have ran them across the factory crossmember in front of the Dropmember (that's how the 73-87 lines are ran). It's a bit easier and less hassle bending the lines if you go the 73-87 way.
www.PorterbuiltFabrication.com
Phone: 480-297-2621
E-mail: sales@pbfab.com
Find us on FaceBook under Porterbuilt Fabrication
Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck.
We offer components from the following manufacturers:
Porterbuilt
Accuair
Ridetech (Air Ride Technologies)
Air Lift
Wilwood
Intro
Unisteer
ECE
Gotta Show
Air Lift
Borgeson
CPP
Supporting this forum since 2003!
PBFAB.COM is offline   Reply With Quote
Old 12-30-2008, 02:50 AM   #6
royo
royo's Avatar
OK then thanks guys. I dont care to replace them I just want to do it one time and be done
nickle and dime
Old 12-30-2008, 01:06 PM   #7
SCOTI
SCOTI's Avatar
I had the lines routed like the 73-87's as mentioned but the frame is now stripped of all that stuff so I can't help w/pics. It did require tweaking the lines on the pass side to route through the frame braces.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
