Odd spark plug wear
I am hoping some of you have seen this kind of pattern before and can explain to me where I should be looking for a cause. This is a 350 TBI motor that has gradually started to get intermittent misses, getting worse over time. I pulled the plugs and all 8 of them have a dark gray spot going down the insulator, some with deposits on the spot also. I have attached a couple photos to show what I am trying to describe. These plugs have almost exactly 10,000 miles on them. Thanks for any help.
72 Chevrolet C20 LWB Fleetside 89 Toyota Supra Turbo 87 Toyota Supra (DD) 95 Ford Thunderbird (4.6 V8) 95 Chevrolet Tahoe |
Re: Odd spark plug wear
increase the carburetor jet size slightly, take out some timing, or go to a colder plug.
from: http://www.dragstuff.com/techarticle...ark-plugs.html
RN U OVR |
TBI motors dont commonly have carbs
ASE master tech/machinist
Go to a colder plug, CR43TS ac delco is the factory plug for TBI trucks, as stated above by senator back some timing out of it. On a TBI motor you have to unplug the "timing control module" which looks like a breaker, that is what controls the advance instead of a vac advance. Dead nuts zero timing is "ideal" per GM, but any place between 0 degrees, and 6 degrees after will work. Also make sure there is no exhaust leaks, with plugs like that a burnt valve is a possibilty. The deposits are cause by the wet fuel that lingers around the exh valve in the chamber. If you can burn that fuel, your problem will burn with it.
