Old 12-04-2002, 06:58 AM   #1
sewanhaka62
gas gauge
hi
put a subburban tank in rear of my 67 pickup--new tank with new sending unit--when i fill up the gauge reads about a 1/2 inch pass
full---is there an easy fix to bring it back to normal
thanks
bob
sewanhaka62 is offline   Reply With Quote
Old 12-04-2002, 09:30 AM   #2
Huck
Huck's Avatar
Check GMC pauls web site. You need something in line for the suburban tank for the gauge to read correctly.
Huck is offline   Reply With Quote
Old 12-04-2002, 02:40 PM   #3
cableguy0
i have a stock tank and sending unit and mine has always done that since i've ridden in the truck 8 or 10 yrs.
Owner of North Point Car Care in Dundalk Md. We specialize in custom exhaust on both modern and classic vehicles. We are a full service auto shop from classics to modern vehicles. Feel free to contact me with questions. I will give a 10% discount to any board member.
cableguy0 is offline   Reply With Quote
Old 12-04-2002, 03:01 PM   #4
BobbyK
BobbyK's Avatar
Location: Petrolia,Ontario,Canada but working in Port Huron,Mi.
Mine goes above full as well.As long as it reads empty on "E" and not 1/4 tank ,I'd say don't worry.
71 blazer,350SBC,approx.375HP,700R4,factory GM TPI.Dual electric fans,33x12.5x15 ATR on stock suspension.
Petrolia,Ontario,Canada but working in Port Huron,MI.
See ALL my Blazer pic's HERE
BobbyK is offline   Reply With Quote
Old 12-04-2002, 05:30 PM   #5
gman
So if the gauge reads between 1/4 and 3/8's of a tank when EMPTY, what's the problem? Bad sending unit or what? At full its about 1/4 to 1/2 inch past full. This is my situation.
72 Chevy SWB Custom Deluxe K10, 350/SM465, PS, PB, Fact. Air
2000 Harley...Wide Glide
gman is offline   Reply With Quote
Old 12-04-2002, 06:04 PM   #6
special70gmc
special70gmc's Avatar
when mines empty it reads alittle a bove a 1/4 too it really botheres me wats up?
1986 c-10 swb 5/7 drop 20'' coys
1958 belair 2door
special70gmc is offline   Reply With Quote
Old 12-04-2002, 06:12 PM   #7
Long Knight
Spank 'em if you got 'em!
Long Knight's Avatar
Just bend the lever! (worked on my original sending unit) lol
Long Knight
'71 C-20, 350ci, TH350, Edl. 1406 Carb w/elec.choke, Ignitor ignition, Viper Tires, Orange Dipstick
Long Knight is offline   Reply With Quote
Old 12-04-2002, 06:24 PM   #8
gman
Sorry, but what lever are you referring to. I'm not too knowledgeable about this issue, so my apologies. The long rod with the float attached?
Old 12-04-2002, 06:51 PM   #9
Long Knight
Right, my guage read wrong after I fixed the float (probably because of the added weight of the solder!LOL) Filled the tank and make the necessary adjustments by bending the rod. I know I reads just right now because I ran it on E for a while and was about 20 feet from the gas pump when it died.
Like I said, this worked on my old tank. New tanks might be a different story. It's always cheaper to bend then to buy. jmo
Long Knight
