Old 12-30-2008, 10:30 PM   #1
allen123
It'll buff out
allen123's Avatar
Is this not the original master cylinder?
I was needing a new gasket for it and I went up to the store and they didnt have anything like it and they looked in the parts book and the closest gasket that looked like it was out of a mercury. Then he pulled out a whole new cylinder and it looked nothing like mine.
1972 Chevy c10 swb
2008 CBR600RR Grafitti edition
My Build
Cody Allen
allen123 is offline   Reply With Quote
Old 12-30-2008, 10:39 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
Re: Is this not the original master cylinder?
It could be that his replacement M/C is very well different than what you have. As to the gasket, have you looked at the Help Parts displays at O'Reilly's/AutoZone/Advance? Those parts displays have lots of little (so to speak) parts that you and others need for the little (so to speak) jobs that come up. NAPA should be able to find one in their myriad of parts books. If nothing else, what about a GM dealer? Just because these trucks aren't new, doesn't mean that they don't have/can't get a lot of the little parts that are still relevant, even today.
Member Nr. 2770
Old 12-30-2008, 10:54 PM   #3
dave2953
Dave's not here, man
dave2953's Avatar
I agree with ChevLoRay on the "Help" section. Before I swapped to discs I was able to find a gasket for my original master this way.
- 2014 VW Jetta
- 2015 VW Jetta
- 1966 Ford F-250
dave2953 is offline   Reply With Quote
Old 12-30-2008, 11:26 PM   #4
71 super
71 super's Avatar
Looks like original m/c to me- bendix type. As others have said check out the help section that is a pretty common m/c setup and there should be one that matches it in that section. You have to be careful with advance and others like them, the counter people have an adversion to using a parts book instead of the computer.
67 blue step side- bb
68 gold and white swb cst anniversary
68 custom swb hot rod Ls swap
69 swb cst 6 cylinder/ overdrive
69 black/black cst bb swb
70 orange and white cst Canada built truck swb bb
71 black and white super swb bb
71 red and white super swb
72 green and white super swb 4x4
62 nova wagon 400 series Ls swapped
68 Camaro 327/4 speed- 1 owner, original paint
66 Volkswagen bettle
69 auto stick Volkswagen Beetle
71 super is offline   Reply With Quote
Old 12-31-2008, 03:23 AM   #5
Aarons72s
I like the spark plug heater hose plug. :
As to your mastercylinder. It looks like a stock non power master cylinder. I bet they are trying to give you one that has two locking rings and is a little bit larger right? If so you should be fine. Some say you cant swap them for each other. But I have seen both mounted oposite. My green and white had one like you got on it when I got it, and it was factory power brakes. I replaced it when I rebuilt the brakes with a reman one that was the larger, double latched one. That is the correct and original one for my power brake truck. So dont be to concerned with the shape of the replacement. As there are alot of them that interchange.
Just when you get the new one make sure the back is similar and that the hole in the middle of the piston is the same shape and depth. Also make sure the outlets are the same size and in the same location. Good luck.
Aarons72s is offline   Reply With Quote
Old 12-31-2008, 10:08 AM   #6
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
The one that came with mine looked different, but I changed it out and now it looks like yours.
Has mentioned that you should remove your flex fan?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 12-31-2008, 02:09 PM   #7
allen123
It'll buff out
allen123's Avatar
Yeah i've been told to get rid of it
1972 Chevy c10 swb
My Build
Cody Allen
