Im afraid of purple hangers..
What CFM is this carb?
I am looking all over the net for info. found its a 1970 Rochester quad but not what cfm it is.
numbers are below 7040206 1 F 22091 any help? 750 or 800? This is off a Bone stock 396 three speed auto with a non posi Last edited by bsgmcc20; 01-01-2009 at 12:37 AM. |
"THE GREEN GOBLIN"
Re: What CFM is this carb?
I have No Idea but heres A bUMP--^
![]() "THE GREEN GOBLIN" 1972 Cheyenne 10 Short Fleet Side Front 2.5inch Spindles with 2inch Springs Rear 4inch drop Springs. 454BBC TH400,Posi 1971 Cheyenne 10 Long Fleet Side 454BBC TH350,Posi ![]() Drive it like you stole it! ![]() Petey-pablo@sbcglobal.net |
Active Member
I found a 7040200 that is correct for 1970 396-400-454 for passenger car, vette, camaro, nova, & monte
They do not list the CFM but normally the BBC units are the higher flowing units I also found a 7044206 which works for a nova or vette in 74 with auto - that would be a smaller cfm card You should be able to find a 4 diget date code stamped into the base of the carb on the throttle lever side near the back bolt hole
1968 SWB 454 + .040, 490HP x 540 FT pounds of Torque 10-1 Kb Forged pistons, recon rods w/ ARP wave loc bolts 781 heads Ported with 2.19/1.88 SSTvalves Lunati 60204 cam, Micro Trol lifters, Ported Edelbrock Performer Rpm manifold armor coated, Pertronix Triple Strike Ignition Holley 770 Street Avenger carb,Headers armor coated Built by Watson Ruppel Performance in Sarahsville Ohio. Hardshift Tranny Built Turbo 350,TSI 10" 3000 stall 12 Bolt Eaton Posi 4.10 Richmond Gears moser axles ![]() 18.5" x 31" Hoosier Pro Street Radials ![]() ET Classic 5 Wheels - polished Power Steering, Power Brakes,Disc Brakes,Tach & Gauge Dash, Tilt,Factory Air (gone) Custom Paint & Body Work Special thanks to my wife, my son and my money tree ![]() |
Do you have the carb? If so here is a pic of the difference:
http://dyeager535.topcities.com/qjetidentify.html
![]() ![]() 99 Pontiac S/C GTP, SLP Ram Air hood, GMPP Konis & springs 95 Neon ACR, MP PCM, AFX UDP, 3.0 CAI |
Most Q-jets are 750 cfm some Buick and Cads ran 800 the link neon sent shows the difference
Active Member
![]() Join Date: Aug 2008
There is a decoder
Rochester Number decoding Example: # 7028219 DG 1938 7028219 Prefix code. "70" will appear on all late '60's Rochester Carburetors. 76 and later will start with "170" 2 - Decade produced. 702 - 1960's 703 - 1060's with A.I.R. 704 - 1970-1975 1705 - 1976-1979 1708 - 1980's 7028219 Year produced. 8 = 1968 If the number was 7045219 then 5 = 1975 7028219 Model 0 - Monojet (1 bbl) Federal standards 1 - Two jet (2 bbl) Federal standards 2 - Quadrajet (4 bbl) Federal standards 3 - Monojet (1 bbl) California standards 4 - Two jet (2 bbl) California standards 5 - Quadrajet (4 bbl) California standards 6 - VariJet (2 bbl) Fed 7028219 - Division. 0, 1, and 2 all indicate Chevrolet. 4 - Buick 5 - Olds 6,7 - Pontiac 7028219 - Transmission Even numbers - Automatic Transmission Odd numbers - Manual Transmission DG Production Plant Code. 1938 Date Code 193 = 193 rd Day of the year 1938 8 = Year |
Thanks for all the input.
The "bump" is what i need to look for. The Holley i have on it is a 650 off my other 72 with a 400sb. I was doing research on the quad and wanting to rebuild it and keep it orginal as much as i could. The Molding was damaged so that is the only casuality as of yet. My idea for paint is white top with British racing green bottom. http://fyi.gmblogs.com/2007/04/from_...ve_1970_2.html Here is a GM photo of the color idea The green for the bottom http://www.teglerizer.com/mgcolors/ Dark British Racing green Paint code PPG 9767 Last edited by bsgmcc20; 01-01-2009 at 10:42 PM. |
If you are looking for one, I have had good luck finding them on older caddies at pic & pull. Also look for one with an electric choke. And I would plan on a rebuild including rebushing the throttle shaft (possibly even changing the throttle shaft depending on linkage setup).
Old Skool Club
![]() Join Date: Jun 2001
Jokers69....what a nice thing to post. I had seen that info before, but my damaged brain didn't dig it out of the annals of time, where it was buried. So, it looks like a 1970 Chevy Q-Jet for an automatic, without saying which engine it was on.
Member Nr. 2770 '96 GMC Sportside; 4.3/SLT - Daily driven....constantly needs washed. '69 C-10 SWB; 350/TH400 - in limbo The older I get, the better I was. |
