01-01-2009, 11:48 AM | #1 |
Engine Wire Protection
What are you guys using to protect the wires running around in the engine compartment? The factory braided cloth was shot, so I need something to put over the temp, oil sending wires.
01-01-2009, 12:37 PM | #2 |
Re: Engine Wire Protection
I use heat shrink you can get it in several different colors and diameters, slip the appropriate length over the wire heat shrink just a half inch or so on each end and yur good to go engine heat may eventually shrink it down depending on the heat intensity in your engine compartment looks a lot cleaner than the ribbed tubing for lots of applications.
01-01-2009, 12:40 PM | #3 |
i use flexable plastic conduit. you can get it in different sizes and is available at most auto parts stores.
01-01-2009, 12:45 PM | #4 |
the factory cloth braided stuff is readily available,i like using it . i get it at larger swapmeets from the restoration supply vendors
01-01-2009, 01:35 PM | #5 | |
Watch out for your cornhole !
Rhode Island wiring is where I get all my electrical stuff from.
01-01-2009, 01:37 PM | #6 |
I agree with cdowns, take a look at his ebay link, its good stuff and he has different sizes.
http://cgi.ebay.com/ebaymotors/ASPHA...Q5fAccessories Jeff
I'm not a pessimist, I'm just optimistic that bad things are going to happen. 1971 Cheyenne Super K10 - tilt, cruise, air, am/fm, tow hooks, factory buckets! 1986 Jeep J10 pickup, - 5.3L Vortec with 4L60e and NP241. |
01-01-2009, 01:52 PM | #7 |
thanks for the link. I think that is stuff I will go with. What sizes are you getting for single wires? I thought all the stock stuff was single wire runs.
01-01-2009, 02:00 PM | #8 |
New Member
I just re-did most of my engine bay with this stuff: Looks really nice and says it is heat resistant to 275 degrees.
http://www.parts-express.com/pe/show...number=082-300 |
