Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-01-2009, 03:17 PM   #1
fast75
Go Hard or Go Home!
fast75's Avatar
another hp question
i have a 350 bored 40 over, pre unleaded heads, 202 intake, 160 exhaust, lunati 468 lift cam, victor jr intake, edelbrock 600. any ideas how much hp this is putting out? this is in a 75 short wide, it feels stout and WILL get stupid with you. the wife is afraid to ride in it anymore, lol.
fast75 is offline   Reply With Quote
Old 01-01-2009, 04:36 PM   #2
Pyrotechnic
Pyrotechnic's Avatar
Re: another hp question
You are probably making around ~350 HP at the crank with that setup. I'm guessing that number is going to be higher up in the RPM range because of the Victor Jr. intake.
I can get you some Desktop Dyno numbers if you want, but I'd need a lot more specific information for that. If you want a DD run, I need:
Casting number of heads
Compression ratio
Part number of camshaft
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 01-02-2009, 06:12 AM   #3
fast75
Go Hard or Go Home!
fast75's Avatar
Compression ratio
thanks Pyro, i'll get those casting numbers for you
Old 01-01-2009, 06:20 PM   #4
bigjimzlll
bigjimzlll's Avatar
I'd bet around 275-280 Hp and 300 ftlbs of torque on a good day.
The actual number means nothing. If it's fun(and a little scarry) then it's almost enuff.
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 01-05-2009, 08:46 AM   #5
djracer
djracer's Avatar
I'm surprised it runs good with a 600 on a vic Jr. I tried one of those intakes on an old motor I had and it was too much intake for my 355 small cam combo. The best way to tell what it will do is take it to the track. You can get pretty close with the truck weight and some run info.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-05-2009, 09:06 PM   #6
41 chevy
Thumbs up Re: stock bore sbc hp
Can someone give me a knowledgable guess how much hp this combo will give me? 350 small block, stock bore, flat top pistons, Summit 202 straight plugs 67cc, 195 runners {cast iron} , Comp. cam @ .50 224/231 dur. 477/480 lift, Howard hdy. lifters, 1.6 roller tip rockers, Acel high energy dist., performer dual plane intake, 600 Edelbrock carb, block hugger headers 2.5 collectors. Thanks for your opinions. Steve
41 chevy is offline   Reply With Quote
Old 01-05-2009, 09:15 PM   #7
djracer
djracer's Avatar
welcome to the board I would guess about 375.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 01-05-2009, 09:35 PM   #8
bigjimzlll
bigjimzlll's Avatar
Kevin....did you just say 375HP?
Anderson,CA
Old 01-05-2009, 11:31 PM   #9
djracer
djracer's Avatar
give or take 100
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 01-16-2009, 04:07 AM   #10
ProStreet71
Fast75, you would be alot better off with the performer rpm intake... Just my 2 cents
ProStreet71 is offline   Reply With Quote
Old 01-16-2009, 04:36 AM   #11
fast75
Go Hard or Go Home!
fast75's Avatar
well sheeit, ya think so? well that sucks, i bought the victor jr new from jegs on the advice of one of their techs. i bought a demon carb, 750cfm at the same time and couldnt get it to work to save my life. sent it back to barry grant twice and they said there was nothing wrong with it. so i sent it back to jegs and got the 600 edlebrock. is the victor jr too much intake for my set up or what? the truck seems to have plenty of power and runs fine, but if i punch it, it seems to bog down. i cant get the power to the ground it seems, what gives??? i appreciate your input and thanks again.
75 short wide 350, some mods, scare the piss outta ya quick.
2008 Dodge crew cab. YEAH, it's got a hemi, your ass is going to jail quick.
Some day's, it's just not worth chewing through the restraints................................
Old 01-16-2009, 05:35 AM   #12
ProStreet71
Sorry for the bad news... but you need a dual plane intake for the setup you have. Single plane intakes arent good for the street unless you are building a max effort street/strip engine. You are probably giving up 15-20 lb-ft of torque down low were you you really need it.
When you install bigger cams, intakes, carbs, etc, you most likely have to raise your initial timing. What is your timing set at now? this could be causing your bogging problem. What is the duration on your cam? If you have too much and didnt change your torque converter it will bog when taking off. Also larger cams and high rearend gears can cause this.
Old 01-17-2009, 06:00 AM   #13
fast75
Go Hard or Go Home!
fast75's Avatar
i've got the timing right, its burning clean at the plugs, idles good and runs great. i have a Pertronix flame thower distributor. it bogs slightly if i try to do a burnout or 20 mph punch. i still have the original 3 speed with a zoom clutch and the original 12 bolt limited slip rearend in it. i've since gotten a posi 12 bolt to put in it when i change the gearing, and a power glide tranny that needs going thru. hopefully i'll have these in the truck this summer. my thoughts have been it was this area that was causing my problem. the buying of a new intake is cheap so i'll do that first, hell it makes sense to me. whats the biggest carb you would run with my set up on a performer rpm? unlike most, im not worried about gas mileage on this truck, its a weekend cruiser spending most of its life in the shop. its a sweet little truck, fun to drive, sounds great, turns heads, and keeps the 20 year olds in mustangs on their toes. it just seems that as much money as i have in that motor the damn thing ought to bake those Mickey's on the back. thanks again, Pro Street and the rest of you guy's..............Fast75
Last edited by fast75; 01-17-2009 at 06:05 AM. Reason: i have a 468 lift lunati, not sure of the rear gearing, im thinking .342
Old 01-18-2009, 01:51 AM   #14
ProStreet71
Fast75, I would not use the powerglide in your truck because it is only a 2 speed and they were designed for a light vehicle. It would make a dog out of your truck. If you really want to change trannys, i would go with the th350 or th400 with approx. a 2000-2500 stall depending on your cam specs and 3.73 gears. Although i dont like edlebrock carbs the 600 should do fine. By the way, they have two versions of the eddy carbs. Performance tune and gas econo tune. Back to your bogging problem, i still believe its a good possibility its in your timing. You may need to put a curve kit in it to change the rate of advance. What is your initial timing set at? What is your total timing? I realize your plugs are clean and runs well but your timing could still be less than optimal... Basicly only 2 things will cause this, the tune of your timing curve or the tune of the carb. BUT, if you are goin to change intakes i would not change anything until that. The correct intake will require a dif tune and you may not have to change a thing. Never change more than one thing at a time.Sorry for the long reply. Hope this helps.
Old 01-18-2009, 01:58 AM   #15
custom72c20
custom72c20's Avatar
[QUOTE=ProStreet71;3093099]Fast75, I would not use the powerglide in your truck because it is only a 2 speed and they were designed for a light vehicle. It would make a dog out of your truck. If you really want to change trannys, i would go with the th350 or th400 with approx. a 2000-2500 stall depending on your cam specs and 3.73 gears.QUOTE]
You took the words right out of my mouth. haha. I agree that the victor jr. is too much intake for the cam. The victor jr. is for cams making power in the 3,500 to 7,500 rpm range and with the cam you have, your only touching on a small part of the intakes powerband. IMO
Nick
Old pic of my 72: http://img340.imageshack.us/my.php?image=img0435co5.jpg
04 Silverado Daily Driver
68 GMC short step http://67-72chevytrucks.com/vboard/s...d.php?t=379665
"I'll beat you to the gas station!!"
custom72c20 is offline   Reply With Quote
