01-02-2009, 12:32 AM | #1 |
Wheelin' and Dealin'
65 window re install
ok so i had to take my windows out a while back with all the mechanisms and everything and now me and pops are ready to put them back in,we have never done it before and know how much of a pain it was to take em out,
so basically what im getting at is do you guys have any pictured installs or word of advice/wisdom it would be more than appreciated
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside Porterbuilt Extreme front and rear 12bolt w/ eaton tru-trac 4:11 gears 1BADD65 my build thread: http://67-72chevytrucks.com/vboard/s...=1#post2601700 Last edited by Hillbilly Deluxe 65; 01-02-2009 at 12:33 AM. |
01-02-2009, 02:36 AM | #2 |
Re: 65 window re install
Hardwaa and I just did this to his truck. I have installed many windshields in various cars and trucks and this was one of the most difficult installs i've done , so my advice is find someone who has some experience even if it means letting a few moths outa the wallet!Good luck.
2-20, 2-21 whatever it takes! |
01-02-2009, 01:55 PM | #3 |
65 - Chevy C10
Good cord string and lots of wd-40! After seeing the guys install mine i was pissed i spent the money for it. I think I could have done it.
01-02-2009, 02:23 PM | #4 |
sorry i meant side windows along with teh vent window i already have installed teh windshield and back glass
1965 Chevy c-10 fleetside long bed with 06 gto LS2/T56 inside Porterbuilt Extreme front and rear 12bolt w/ eaton tru-trac 4:11 gears 1BADD65 my build thread: http://67-72chevytrucks.com/vboard/s...=1#post2601700 |
01-02-2009, 11:26 PM | #5 |
If you put things together in the right order, it's not too bad. I usually put the vent and the regulator in first then the glass. get that started in the track then line everything up and bolt it down. The trick is leave it all loose until the end. If you cant get it, I'll be down your way in the next week or 2 I can swing by and give you a hand if you need it. Feel free to hit me up if you have questions.
65 Chevy C10 Panel http://67-72chevytrucks.com/vboard/s....php?p=7148391 42 Chevy 3100http://67-72chevytrucks.com/vboard/s...92#post7184392 96 GMC K2500 Diesel Suburban 89 GTA Trans Am Convertible. |
01-03-2009, 12:21 AM | #6 |
i appreciate it man we got one thru trial and error and the next one will be a breeze only problem we are having witht eh drivers do is that the door wont shut right with the new rubber, before the new rubber it you still had to slam it but now that its an issue im thinkin it might be the door latch that has just been worn out and the gear inside wont quite click on the last tooth it needs to
sorry to ramble, but any thoughts?
01-03-2009, 12:35 AM | #7 | |
