01-04-2009, 12:42 PM | #1 |
how to swap engines without hoist?
how have ya'll done it? i need to do it outdoors. i do have a little concrete pad.if i can swap the engine and tranny to my better truck i might have enough motivation to keep it.
01-04-2009, 01:05 PM | #2 |
Re: how to swap engines without hoist?
I wouldn't recommend it. Doing that will turn a few hour job into a days long nightmare. You would have to take the engine apart and separate the trans to get the weight down enough to even lift it. Go to a tool rental place and rent a engine hoist for a weekend, or even find a strong aframe and hook a come along to it if you have to. Get everything loose pick up the engine and trans in one piece and roll the truck to get it out.
65 Chevy C10 Panel http://67-72chevytrucks.com/vboard/s....php?p=7148391 42 Chevy 3100http://67-72chevytrucks.com/vboard/s...92#post7184392 96 GMC K2500 Diesel Suburban 89 GTA Trans Am Convertible. |
01-04-2009, 01:17 PM | #3 |
i think you can buy a hoist for like $99 now. Would be enough to lift a small block. After you are done you could sell it for $50 and if it takes you a week it will be cheaper then renting one. Orrrrrrrrrrrrrrrrrrrrrr See if there is a board member near by that might have one that can help you out.
"A man and his truck, what a beautiful thing" 65 Short Fleetside BBC 65 Long Fleetside 283 3 on the tree for now. my build thread http://www.67-72chevytrucks.com/vboa...d.php?t=259536 |
01-04-2009, 04:46 PM | #4 |
Hey Y'all!!
Gotta any big trees with strong, low limbs? That and a come-a-long(sp?). Done it this way a long time ago...
01-04-2009, 05:03 PM | #5 |
One day...
Now just how buff are you
Its all fun and games until you get to the block itself unless its stripped too but its still no fun.. Id try as Tim suggested, but i would find an oak tree then maybe if it did break you may not suffer as long Last edited by scotts62; 01-04-2009 at 05:05 PM. |
01-05-2009, 12:44 AM | #6 |
I got a used one , it was chained to a tree with a for sale sign on it 50.00,I oferd him 35, and got it for 40. I sold it after for 60.
Rent one, borrow or buy, you will save time, and maybe your life
1960 Apache long bed fleet L6 250 Clifford intake 2 bbl carb. Langdon cast headers with dual exhaust and bellflower tips. T-5 5 speed, power steering and power disc brakes. "Over, Around or through it... " |
01-05-2009, 12:49 AM | #7 |
One day...
Too bad it wasnt inside, i use a 6x6x10 across rafters in shop with a chain hoist and it works better than messing with a picker.
01-04-2009, 06:08 PM | #8 |
Do you have a friend with a tractor with a loader or a fork lift?
I've used all methods available except the disassemble and remove piece by piece that don't soud like too much fun A fork lift or loader tractor is an extremly versitile shop tool
60 4x4,235,SM420,Rockwell T221,D44/HO33 sold 4/12 67 C-20,292,SM420,HO72 90 Dodge W250 Cummins,NV4500HD,205,D60/D80 93 Dodge W350 Dually Cummins, Getrag, 205,D60/D70 |
01-04-2009, 06:51 PM | #9 |
Kinda like this but use it on the engine.
01-04-2009, 06:54 PM | #10 |
You might consider posting an ad on craigs list for a temporary use of an engine hoist. You never know, you may find a generous person in your area that likes to wrench and help others with their projects. I would loan you mine, but I am a long way from Ozark, AL.
Good luck and let us know what you do. |
01-04-2009, 06:56 PM | #11 |
1tractor
2 tree 3 one large post across your lumber rack crosswise under the rails at the middle One long large post over the back of the rack lengthwise, with the forward end under the crosswise post so as to create a boom. Be sure the rack is well attached, once you hang a come along and motor off the high end, it is going to be under a lot of strain. I did a Lincoln 462 with trans this way, but my rack was really beefy. obviously, something might break, so don't be under the motor.
68 Chevrolet k20 Longbed 350 SM465/205, Dana 44, 14bolt, Power steering, Power Disk Brakes, 35" BFGs. 84 Chevrolet Suburban K20 6.2 Banks turbo TH400/NP208 Now with G80 68 GMC C20 Parts? Truck And a few cars |
01-04-2009, 06:58 PM | #12 |
renting is cheap and safe
CHEVY ONLY |
01-04-2009, 07:03 PM | #13 |
Registerd User
01-04-2009, 07:05 PM | #14 |
Yep, A fork lift also makes an awsome high lift jack
01-04-2009, 07:15 PM | #15 |
CHEVY ONLY |
01-04-2009, 07:48 PM | #16 |
thanks for the ideas. i'll start asking around to find someone with a hoist. who's the closest to ozark, al. 36360
01-04-2009, 07:51 PM | #17 |
Registerd User
I'd go to the clubs forum and look in your regin.
01-04-2009, 08:55 PM | #18 |
Hollister, CA.
No sweat....myself and one other buddy did it to a big-block......
Big-Block Samurai engine that is !! Seriously, you must do this safely...borrow, buy cheap, or rent a picker bro... Take the above advice !!
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
01-04-2009, 09:28 PM | #19 | |
years ago i pulled a short block 4 cylinder out of a sidekick by hooking a strap to it and just physically lifting it out by myself
CHEVY ONLY |
01-04-2009, 10:11 PM | #20 |
100% gearhead
Two of my buddies did a smallblock into a '63 by bolting on the headers and lifting it in. They said id sucked and never try it. Another buddy and me took a 2.8 out of an S-10 with a ladder, a 2X6, and the golf bag strap from a golf cart. It worked and was really funny.
01-04-2009, 10:47 PM | #21 |
Hey Y'all!!
Another suggestion is a "boom pole" on the back of a tractor. Used this method to pick up the frontend of a crusher bound vehicle to get the trailer under it.
I'm 150+ miles from you. |
01-04-2009, 10:58 PM | #22 |
One day...
this is getting bad, Hey man be safe dont listen to all this funny stuff!
I agree borrow of some sort |
01-04-2009, 11:03 PM | #23 | |
wish you had pics of that
CHEVY ONLY |
01-04-2009, 11:11 PM | #24 |
Designated A-hole!
Where is Ozark? Nevermind I looked it up and you're a few hours from here. If you have a tree with a stout limb within reach a chainfall hung from it does wonders. I've actually pulled the engine out of a Freightliner like this, but it was a huge oak and a large chainfall.
"If it ain't broke, fix it 'til it is!" Being stupid ain't illegal. We're Still Debt Free Except for the House!!! www.daveramsey.com 70 GMC SWB Stepside project "Green Booger" soon to be 6.0l/4l80e 93 S-10 "Poppaw's Truck" |
01-04-2009, 11:27 PM | #25 |
I know you said outside but...
I used to do it this way before I got an engine hoist. Scab a couple of 2X8's together and suspend them from the joists of a garage or basement. When it is time to lift something, put jack posts under each end, and use the old come-a-long. On second thought, beg, borrow, or steal the engine hoist. TR
1965 C10 SWB Fleet Two owner LS2 Swap Thread http://67-72chevytrucks.com/vboard/s...d.php?t=413880 |
