01-04-2009, 11:32 PM | #1 |
Blazer roof rack For Sale
I pulled this off my 71 blazer. It is super sturdy but also very light weight. I figured I'd offer it up to the board first. I'm asking $125.00 Thanx Dana
1972 Cheyenne K-30 6"lift {502 PROJECT} 1972 Cheyenne K-30 8"lift 454 450hp {Ol'Blue} 1972 Cheyenne K-20 Custom Stretch 6" lift 454 1972 Custom Deluxe K-20 4" lift 2007 GMC Crew Cab Diesel 6"lift {The Tow Rig 2017 Ford F-350 Crew Cab 6.7 6"lift (Wife's) 1977 El Camino SS Grandpa baught new 1986 K-30 Crew Cab 502 1955 Chevy 2-Door gasser 454 550hp{project} 1956 Chevy Bel-Air 2-Door hardtop 572 700hp 1979 Ford F-350 All Original 4x4 (Wife's) |
01-05-2009, 12:16 AM | #2 |
Re: Blazer roof rack For Sale
Is the rack rusty at all? Assuming that it is bolted through the roof (correct?) do all necessary brackets/bolts come with it?
I do not know the difference between a single wall and double wall top (help here - anyone !!) so must ask if it will work for both? Thanks for any info. CCCC
CCCC 67 Sting Ray Coupe 327 4sp; 68 K10 Suburban 327 4sp; 69 K20 Lifted 383 4sp; 69 C80 Fire Truck 478 V6 5sp/2sp; 69 C20 Longhorn 327 4sp; 70 C30 Wrecker 350 4sp; 70 C30 Flat Bed 350 4sp; 71 C20 LWB 350 4sp; 72 K5 Blazer 350 4sp; 72 C30 Flat Bed Gooseneck Hauler with sleeper 350/TH400; 72 C20 Longhorn 402 4sp; 52 Mack LTL Supercharged Cummins 5sp x 3sp; 01 Dodge 5.9 HO Cummins 6spd; 02 Safari Trek 2430 8.1 Vortec on Workhorse Chassis; 03 Silverado 2500 HD 4wd Duramax/Allison Moved but still in the family 70 C20 Custom Camper 350/TH350; 72 K5 Blazer CST Highlander 350/TH350 Recently sent to new homes 72 C30 MoHome 402 4sp; 72 K5 Blazer Conv 350 4sp; 75 GMC 6000 Aerial 350 w Allison; 72 GMC 3500 Utility 350 4sp; 70 GMC 3500, 350 4sp |
01-05-2009, 12:24 AM | #3 |
pic on the blazer.
01-05-2009, 12:39 AM | #4 | |
Double wall tops dont have exposed bolts from a "back seat" view. The side panels need to be removed to remove the top. Bolts run from the bottom of the bed side rail and into the bottom of the top. Double wall tops were factory installed on 1969-1972 blazers. Some time in 1972 they switched to single wall tops, but I'm not sure when. Both tops have different bolt patterns. Some 1972's have double wall holes, some have single wall holes, and them some of both. |
01-05-2009, 01:26 AM | #5 |
Not to hijack this thread, but thanks a lot Mint68. I get the full picture and, even without going out to the garage to look, now know that two of my 72s have double wall tops. The third Blazer came to me with a soft top - so I will need to inspect the rails.
I am thinking about this roof rack for the hunting rig. CCCC
01-05-2009, 12:21 AM | #6 |
It has surface rust where the paint has been scrapped. It just bolted through the top. I have all the hardware. I took the rack off my self. It is a great rack. Just not the look i'm going for. It only had 4 bolts in it, 3/8 bolts if I remember correctly. It should work with both tops.
01-05-2009, 10:13 PM | #7 |
Ttt
01-06-2009, 05:22 PM | #8 |
The LuvShack Garage
Nice rack
01-06-2009, 08:13 PM | #9 |
Hello Bad4X4. I'm still trying to decide if I want to punch 4 holes in the roof of a pretty much original second owner rust-free 72 Blazer - not sure. In the meantime if you do not mind - about your K30 trucks - are they both standard wheelbase and what type of bed behind the cabs? A pic or two, maybe?
Thanks, CCCC
01-06-2009, 09:24 PM | #10 |
Here is a pic of Ol'Blue. It has a Dana 60 front end and a 1-ton full floating 14 bolt in the rear. Both truck's started there life as k-20's. Hope this helps.
01-07-2009, 07:28 AM | #11 |
Mid-week bump for that nice rack ya got.
01-07-2009, 09:39 AM | #12 |
vt are you stareing at my rack??????
01-07-2009, 10:10 AM | #13 |
02-04-2009, 12:55 AM | #14 |
Bump
