senior member
could i get a frame measurement please?
im looking at putting an rci fuel cell in the back and the measurements of the tank are 30 long by 17 wide by 7 high could someone measure if this would fit where a blazer tank would go or does someone just know off by hand heres a link to the one im refering to gastank
69 GMC bagged Last edited by pissonNOS; 02-03-2009 at 12:42 AM. |
senior member
Re: could i get a frame measurement please?
bump i would like to order this tank if someone could please help
69 GMC bagged |
senior member
41 views and no one knows? should this be in another section?
69 GMC bagged |
Saving 1 truck at a time!
The width between the frame rails is 27.5 inches so it won't fit that way. My short wheelbase truck is 18 inches (north to south) and the lwb version should be 26 inches in that direction. Does not look like it will fit.
'68 C20 Longhorn 50th Anniversary 400/TH400 '68 C20 Longhorn 50th Anniversary 468/TH400w/buckets '72 C20 Halfhorn (Longhorn w/o cab and front clip) '69 Flxible Cruiser (look up ugly in the dictionary) |
senior member
http://www.lmctruck.com/features/CB/CBGTN.htm
im just going buy this and would think it should fit??
69 GMC bagged |
Junior Member
![]() Join Date: Nov 2006
I've been looking at these too. But what do you do with your spare? Is there a tank that fits on the frame like the 73-74s?
27.5 is the min. inside dimensions though isn't it. Does it not taper out a bit?
Loose the spare tire mount. Move the rear crossmember further back (or get one from ECE). Shave the inside of the frame 1 5/8" on each side till you get 30" you need. This is one option I am thinking for my '70, only I will be dropping in a Fuel Safe or ATL. Spal's HellRaiser - shows something simular. Only they built the rear half. Last edited by Kayotic; 02-04-2009 at 08:18 PM. |
Good eye...the top tapers but the bottom, which is 27.5 inches, does not taper. The top is about 28 inches and tapers out to 28.5 inches at the back of a short stepside. Probably more on the LWB trucks.
I orginally used a 25x17x10,22 gal. built a box and mounted it flush to the bed
senior member
well i bit the bullet and bought a new aluminum tank from cpp
69 GMC bagged |
I looked at the tank CPP is offering.
They have sold lot of them since they started selling them. I think you will be pleased with the tank; I don't no about CPP. Without looking I think it's 19gal or so. That's what peaked my interest. I think it's the biggest so far commercialy availible for these trucks. Let us know how you like it... |
#12 | |
senior member
69 GMC bagged |
