01-07-2009, 12:46 AM | #1 |
Not a bad nut after all..
Rear Axle Brake Line Fittings
I'm replacing rear wheel cylinders and hard brake lines on the '72 4x4 in my signature. The replacement hard brake lines (that run from the "T" on the differential cover to the wheel cylinders) have 1/8"? diameter thread on the "T" end rather than 1/4"? diameter thread of the old ones. So my local auto parts store sold me the brass adapters pictured, but they won't screw into the "T" because the unthreaded head seems to be too long.
1) Is an adapter the right way to go here and if so where do I get one that fits? 2) I would be okay with replacing the "T" and rubber line up to the frame if I knew of a source for one with the correct thread size and length.
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer Last edited by badpeanut; 01-07-2009 at 12:49 AM. Reason: improve text on picture |
01-07-2009, 12:57 AM | #2 |
Re: Rear Axle Brake Line Fittings
I take it yours looks like this, except w/1/4" fittings instead of 1/8"?....Pic is for reference only....My brakelines are obviously too short....6-weeks and Inline Tube hasn't remedied the problem...
Anyways...mine would have worked out fine as far as fitting sizes go...I did locate a bunch of different brakline fittings (for my frints) at my local custom hydraulic hose guy!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=309288 Last edited by Rack Man; 01-07-2009 at 01:15 AM. |
01-07-2009, 01:44 AM | #3 |
My '71 Blazer has the "T" on the axle tube the same as your '70 pickup, but my '72 pickup has it on a bracket under one of the top differential cover bolts.
'05 Chevy 2500HD 4x4 '72 GMC LWB 4x2 driver '72 Chevy LWB 4x4 plow truck '71 Blazer 4x4 driver '70 GMC LWB trailer |
01-07-2009, 07:07 AM | #4 |
i'd go to a different store /try NAPA they shopul have the proper fittings you need// also try a hardeware store
71c-10 350/2004r/4:11 lowered3/4 longbed/dead by hurricane MEANING OF DEATH::::: SOMEBODY ELSE GETS YOUR STUFF DONT BELIEVE EVERYTHING YOU THINK TAKE MY ADVISE;I DON'T USE IT ANYWAY Last edited by cdowns; 01-07-2009 at 07:08 AM. |
01-07-2009, 08:59 AM | #5 |
That adapter you have is for flare nuts too attach to. Just go to NAPA or some other parts store and buy the size/length brake line you need. This line will already have the fittings you need on both ends. I think the length you need is around 34". Just measure from the "T" fitting to the brake cyl. & take your old fitting with you. This will only cost around $8 or so & be done with it.
1997 GMC Sierra Ext 1965 Mustang |
