Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 01-11-2009, 01:49 PM   #1
Garagedude
Garagedude's Avatar
Braided fuel line and AN fittings
Alright guys well I ordered all my braided fuel line and AN fittings and it gets here Tuesday. My question is what is the best way to cut the braided line, I have heard several techniques all which tell you too wrap the fuel line tight with electrical tape or duct tape where you are going to cut it. What do you guys use to cut it. Some people say a fine tooth hacksaw, some a cut off wheel, a wood chisel, and a tool similar too a bolt cutter. Whats your thoughts and experiences with cutting it?
Garagedude is offline   Reply With Quote
Old 01-11-2009, 06:37 PM   #2
bigjimzlll
bigjimzlll's Avatar
Re: Braided fuel line and AN fittings
I've used both cut off wheel and bolt/cable cutters. Both work well.
The key is to use the same fitting make as the hose. Also be patient and bring alot of band aids
It's called "drag racing" if they called it "tic..tic..WHAM!..BANG! F*&K!!!", they'd have to keep the magazines under the counter with the other men's publications
click the clicky to join the site....
http://67-72chevytrucks.com/vboard/payments.php
67 lwb..first hotrod in 25 years..540 best ET is 9.45 @ 141.44
Anderson,CA
bigjimzlll is offline   Reply With Quote
Old 01-11-2009, 07:59 PM   #3
Ont67shortbox
I agree 100% with Jim, I found a little soap help, I know they have an assy lube but I found soap cheaper and worked as well
Ont67shortbox is offline   Reply With Quote
Old 01-11-2009, 08:14 PM   #4
djracer
djracer's Avatar
cut off wheel, tape and wd40. Make sure to blow it out good to get any shavings out before you use the hose.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 01-12-2009, 10:48 AM   #5
Garagedude
Garagedude's Avatar
Well the stuff gets here tommorow so I am going to try cutting it with the cut off wheel. If I run into any problems I will let you guys know. Thanks for the good advice
Old 01-12-2009, 11:39 AM   #6
cdowns
cdowns's Avatar
i've had my best fastest results with a 3"cutoff wheel and wrapping with duct tape
Old 01-12-2009, 12:16 PM   #7
ulakovic22
Same as above. Very important to make sure the hose is clean before you assemble. I'm messing with some braided line right now and tape isn't holding it well for some reason, so I'm going to try a zip tie as well and see if that helps.
ulakovic22 is offline   Reply With Quote
Old 01-12-2009, 01:24 PM   #8
djracer
djracer's Avatar
The best tape is the real strong stuff with the string in the tape.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 01-12-2009, 08:55 PM   #9
71Dragtruck
71Dragtruck's Avatar
Start out by taking a small needle and poking yourself in the finger tips over and over to get a feel for putting the ends on LOL! But ya anyway I use a metal chop saw, or like they said a cut off wheel, after you tape and cut tap the side of the hose to knock out the ground rubber, a bit of lube on the end and install the fitting oh and measure 3 times cut once.
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 01-12-2009, 10:11 PM   #10
tubbed 68
electrical tape and a hacksaw
tubbed 68 is offline   Reply With Quote
Old 01-12-2009, 10:54 PM   #11
phipp13
THE DAMN YANKEE
phipp13's Avatar
fiberglass impregnated tape (looks like it has white string in it) & the thinnest cutting wheel you can buy. i use .032 x 4" good luck be patient
phipp
phipp13 is offline   Reply With Quote
Old 01-12-2009, 11:07 PM   #12
Garagedude
Garagedude's Avatar
I have a good cut off saw, I might have to give that a try, I hadn't thought about using that.
Old 01-13-2009, 08:02 AM   #13
djracer
djracer's Avatar
keep some really good sharp side cutters around incase the braid frays at all.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 01-16-2009, 06:57 PM   #14
Garagedude
Garagedude's Avatar
Well I am more then half way done putting the fuel line in and putting all the fittings on. I found zip tying with a small zip tie and then wrapping it with the really stretchy type electrical tape works really good. I am really happy with the way its coming out and how it looks.
