01-11-2009, 09:56 PM | #1 |
question about porterbuilt dropmember
if you order a porterbuilt drop member does it come ready for the motor. everyone says it is a bolt in unit. do you have to weld the tabs in for the motor mounts or they already installed. thanks guys
01-11-2009, 09:59 PM | #2 |
Re: question about porterbuilt dropmember
the tabs are already welded on, the unit requires no welding at all.
01-11-2009, 10:24 PM | #3 |
67-72 parts collector,…
The only welding would be for the notch for the rack steering/tie rods to clear the frame.
Give Nathan Porter (porterbuilt) a shout by Pm'ing him directly.
01-12-2009, 12:35 AM | #4 |
As mentioned, there is no welding required on the Dropmember itself. The only welding required it in regards to the notches in the frame for rack and pinion clearance.
www.PorterbuiltFabrication.com Phone: 480-297-2621 E-mail: sales@pbfab.com Find us on FaceBook under Porterbuilt Fabrication Specializing in Chassis and Suspension Components for your Classic Chevrolet Truck. We offer components from the following manufacturers: Porterbuilt Accuair Ridetech (Air Ride Technologies) Air Lift Wilwood Intro Unisteer ECE Gotta Show Air Lift Borgeson CPP Supporting this forum since 2003! |
