12-06-2002, 02:22 PM | #1 |
roof marker lights question
which type of roof marker light was aval. on the 10-20 series trucks? i have seen 2 types. the 1st type is these, which would bolt on to any cab. and then there's these, which required a special cab where the roof was molded to accept these lenses. the ad says for 50-60 series but i have seen these on 10-20 serious (i believe). i have a 72 1/2 ton 4x4 and want to put the correct cab light on it. any help is apriciated. thanks!
12-06-2002, 02:33 PM | #2 |
its all about the +6 inches
This has been discussed before...There were a couple types used, and then even more that were dealer installed too. I am thinking that these ones are the dealer ones.
Another oddity is that some cabs came with a raised circular portion for the cab lights, while others (with the lights listed as an option) did not have the circular portion. |
12-06-2002, 02:46 PM | #3 |
Where's my beer?
I have a roof with the "odd" raised circular portion for the lights, and the guy I got it from said it came from a C-10 4x4, what's odd about my roof is that the lights that go on the corners kind of point to the side not straight to the front as the ones in the middle do and the plastic lenses are not the ones you guys have here.
Paul How do you make the invisible, visible?.........You take it away. |
12-06-2002, 02:48 PM | #4 |
fatman...you got any pics?
12-06-2002, 02:51 PM | #5 |
Where's my beer?
hehehe, I knew somebody was going to ask me this, I'll try to get pics this weekend
12-06-2002, 04:20 PM | #6 |
Resident Curmudgeon
Here is what I've observed over the years.
1. The teardrop style was dealer of aftermarket installed and can be fitted to any pickup truck 67-72 series 10-30. All trucks I've had with these had no mention on option sticker for roof clearance lights. 2. The factory installed clearance lights used a special roof with 5 hockey puck sized raised mounting points. I believe this roof design was borrowed from the pickup series bigger cousins (40-60 series) as cabs are nearly identical. There was always a notation on the option sticker for "clearance lights", not sure verbage or option #. With this option there were 2 styles of lenses used, the round ones on the ebay auction and a more teardrop shaped lens. My observation is that the round lenses were used in 69-70 and the teardrop factory installed ones in 71-72. I have never seen a 67 or 68 with ORIGINAL cab that had factory installed clearance lights though I've not seen every truck ever made. FYI, the factory installed outboard lights face out angled, whereas the 3 center lights face forward. My 72 GMC 3/4 4x4 has factory clearance lights with the teardrop lens. I've seen a 69 or 70 series 40-60 in a junk yard with the round lenses. Anyway thats my take on it for what it's worth.
Currently on or near the homestead: 67 Chevy SWB 2WD stepside 350/3 on tree (Pat's) 67 GMC SWB 2WD Fleet 402/auto (Brian's under construction) 67 Chevy 3/4 ton 2WD 402/auto (Business Hauler) 67 Chevy 1 ton dually 2WD 396/4 speed (Former business hauler, Needs TLC) 68 Chevy 1/2 ton Suburban 2WD 250 six/3 on tree (Brian's Needs TLC) 70 Chevy 3/4 ton 4WD 350/4 speed (Pat's - Disguised as a 68 GMC) 71 Chevy SWB stepside (Crushed by tree - parts donor) 72 Chevy 3/4 ton 4WD (Parts donor) 72 Chevy 3/4 ton 4WD Suburban (Parts Donor) 72 GMC 3/4 ton 4WD 292 six/4 speed (Mine - Disguised as a 67 GMC) 81 GMC 4WD Dually Dump Body 350/4 speed (Business Hauler) 82 Camaro Z/28 355/Super T-10 (Pat's toy) 93 Caprice 9C1 (Brian's Cop Car) 02 Toyota Camry (Reliable but a souless steel and plastic hulk) 2011 2SS RS Camaro M6 Factory Hurst Shifter Maybe I need to sell some of this crap Yet another Bozo with a sawz-all |
12-06-2002, 06:10 PM | #7 |
Believe Jeff got it right. Several trucks in a local junk yard have the hocky puck roofs with the round lights on them. Never paid much attention to them once I saw the condition of the housings and the lenses~~~. The teardrop shaped lights are aftermarket or dealer installed (like them better anyway!). Huck
12-06-2002, 06:55 PM | #8 |
I have an original '71 Cheyenne super (rustbucket) but orig. The roof has the raised hockey puck lights. The glovebox says option # U01 marker lamps. It also has headliner, cargo light, 402/400, & A/C. I've just about given up trying to find a nice replacement cab with all these items. A member suggested finding a rusted cab with a raised light roof panel & patching it into a nice A/C cab. Sounds like a plan?
6T727T2 |
12-06-2002, 07:32 PM | #9 |
We have a 1988 GMC Brigadare truck that has the round hockey puck lights, so I bet replacements can still be bought. In fact the cab is the same as they were in 1966 or 67 only they weren't called brigadares . The door handles and dome light are the same as 67 up pickups.
Buy Sale or Trade 71 3/4 4x4 72 1/2 ton cheyenne 4x4 |
12-06-2002, 09:24 PM | #10 |
Here is a picture of the roof marker lights on my 69 C-30. These lenses are correct for 69-87. The one's that came on the truck were the flat one's in next picture.
71 C-10 SWB 1969 C-30 Custom Camper Motorhome Restoration in progress. 2020 Chevy 2500 Crew 4x4 LTZ Diesel 2024 Chevy Tahoe Z71 4X4 2015 Diamond C 22' HD car hauler Bowie, Texas 76230 |
12-06-2002, 09:27 PM | #11 |
The two types of roof marker lens.
12-06-2002, 10:52 PM | #12 |
Where's my beer?
Hey longhornmail my cab lights are the same as the ones that TxGary has on his truck, even the cab color is the same
07-10-2014, 05:42 AM | #13 |
Re: roof marker lights question
So does anybody know if they ever were available in67 and 68? Or just from 69 up?
And I assume they were only available on the trucks, not the suburbans or panel trucks, correct? Or do factory cab lights exist on the suburbans and panel trucks? (maybe with the hockey puck roof)?
78 Chevy K20 Custom Deluxe, build: http://67-72chevytrucks.com/vboard/s...d.php?t=612104 68 Chevy K20 Panel truck, build: http://67-72chevytrucks.com/vboard/s...41#post7263441 |
07-10-2014, 08:35 AM | #14 |
The Older Generation
Here are a couple of threads on the subject.... sstim has more links posted in his second post in the second thread. http://67-72chevytrucks.com/vboard/s...d.php?t=536322 http://67-72chevytrucks.com/vboard/s...d.php?t=567592 LockDoc
Leon Locksmith, Specializing In Antique Trucks, Automobiles, & Motorcycles (My Dually Pickup Project Thread) http://67-72chevytrucks.com/vboard/s...d.php?t=829820 - Last edited by LockDoc; 07-10-2014 at 08:56 AM. |
07-10-2014, 01:46 PM | #15 |
1970 1/2 ton.
07-10-2014, 02:40 PM | #16 |
I have the same maker lights pictured above on my 70gmc k2500. I have heard them refferd to as a firemans hat type marker lense. Hockey pucks and firemans hats,
1970 GMC K2500 aka MaTeR 2007 Chevy Silverado 1500HD Classic |
07-10-2014, 04:16 PM | #17 |
The tear drop type w/chrome was used up through '68. They could be factory ordered or added. They weren't mandated yet by ICC on C/30 DRW. In '69 the round base all plastic type went into use and that's when the roof pods began. All C/30 DRW trucks got them and it was an option on everything else. In '69 the style was what we call hockey puck,then it went to the fireman's hat. Clearance lamps could be ordered on a Suburban or Panel.
* Thanks for bringing back an ancient thread. Some good old names here. We've worked this stuff out eons ago.
"BUILDING A BETTER WAY TO SERVE THE USA"......67/72......"The New Breed" GMC '67 C1500 Wideside Super Custom SWB: 327/M22/3.42 posi.........."The '67" (project) GMC '72 K2500 Wideside Sierra Custom Camper: 350/TH350/4.10 Power-Lok..."The '72" (rolling) Tim "Don't call me a redneck. I'm a rough cut country gentleman" R.I.P. ~ East Side Low Life ~ El Jay ~ 72BLUZ ~ Fasteddie69 ~ Ron586 ~ 67ChevyRedneck ~ Grumpy Old Man ~ Last edited by special-K; 07-15-2014 at 09:45 AM. |
07-14-2014, 10:18 PM | #18 |
I might as well ad this link to the thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=598129 It is a "how to" I posted about modifying the Harley Davidson turn signal lenses to fit in place of the "Hockey Puck" lenses. They would also replace the "Fireman's Hat" lenses in a pinch. LockDoc
