Old 01-12-2009, 02:17 PM   #1
Cherub
Cherub's Avatar
Stock radiator question
What size fittings are the transmission cooler lines on the radiator?
Cherub is offline   Reply With Quote
Old 01-13-2009, 03:24 PM   #2
idrgbdy
idrgbdy's Avatar
Re: Stock radiator question
i used a 1/2" line wrench to remove the fittings when i removed my old radiator a couple days ago. would guess the line is 3/8"???
idrgbdy is offline   Reply With Quote
Old 01-13-2009, 03:54 PM   #3
red caddy
Mine are 5/16" lines, 1/2" line wrench. Easiest way to hook up most trans coolers (3/8ths tubing) is to hit the local hardware store and pick up a 5/16"inverted flare" to 1/4" female pipe fitting (straight, 90* and 45* are availible) and a 1/4 pipe to 3/8ths hosebarb fitting. no cutting or flaring required. The lines stay stock and can be reconnected easily later, if you choose. RED
red caddy is offline   Reply With Quote
Old 01-13-2009, 05:22 PM   #4
Cherub
Cherub's Avatar
Cool, thats what i was looking for Red.
Old 01-14-2009, 09:08 PM   #5
Duro5341
Duro5341's Avatar
When you hook up a tranny cooler, do you hook into the top or bottom line in the radiator on the passenger side?
I was thinking of adding one soon
Duro
-1986 K10 LWB, 350 HD,TH400
3.08, 30 spline 10 bolt, with an Auburn Posi, 31" tires
All original, second owner truck
-1979 Monte Carlo, 350, 200r4, 3.73 posi
-1987 GT T-top Mustang - slow moving project
Duro5341 is offline   Reply With Quote
Old 01-14-2009, 09:58 PM   #6
gchemist
BAD BOW-Silverado XST
gchemist's Avatar
The bottom line should be the return line. Both 350TH and 700R4 have the return line as the top fitting. The out/hot oil line is the lower fitting.
Route the tranny return oil line from the radiator to the external cooler.
Gerardo a.k.a. Mad Chemist
Silverado XST videos
Old 01-14-2009, 11:21 PM   #7
Duro5341
Duro5341's Avatar
not up here in Canada we do it backwards, otherwise this would over cool the tranny fluid in the winter, and cause shifting problems
We rount from tranny pressure line, to cooler, to radiator. This effectively will keep the tranny in proper temp and giving it added cooling efficency when needed
Duro
