Old 01-13-2009, 10:38 AM   #1
jerry moss
Born Psycho
jerry moss's Avatar
dana 44 HYDRA-LOK ?????
off topic for sure but curious if anyone has any experience with this set up. we are putting new bearings on the pinion and carrier in the rear differential of an 01 jeep grand cherokee. i tore it down yesterday and noticed a wierd tin plate on the driver side of the carrier with a couple of small ears and a small wing on it. i was cleaning it in the parts washer when i noticed the plate would rotate. i flipped it over and saw the words HYDRA-LOK cast into it. there is a series of holes in the carrier under the plate and i assume it acts as a hydraulic locking device???? the differential is an aluminum center dana 44. anyone know how it works or if it would work in the front 44 in our trucks??? first one i've ever seen.
jerry moss
72 cheyenne super K20- tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,tow hooks,bumper guards,toolbox,aux. fuel tank,posi front and rear,plus other goodies!!! SOLD
69 suburban K20-tilt,tach,vacuum,speedwarning,buckets,shoulder belts,am/fm,4 inch all spring lift,4 speed, 14 bolt full floater, dana 44 HD,warn winch,posi front and rear,tow hooks,plus other goodies.
73/80 chevy/gmc K20 SB400,turbo 400,205,tilt,a-c,gas hog.
77 K/5 cheyenne blazer-daily driver/beater. SON HAS IT NOW
BRENTWOOD,CALIFORNIA
jerry moss is offline   Reply With Quote
Old 01-14-2009, 08:36 AM   #2
Re: dana 44 HYDRA-LOK ?????
Hmmm...Never heard of that bird.Maybe the 4x4 guys can aswer this one.
Old 01-14-2009, 10:22 AM   #3
jerry moss
Born Psycho
jerry moss's Avatar
Tim,
our head mechanic did a little research on this thing and the tin plate is actually two pieces and the wing act as a pickup tube for the gear oil. there is a hole in the reverse side of the plate and it feeds oil to the holes in the carrier assembly.
jerry moss
Old 01-14-2009, 07:11 PM   #4
CMars45000
CMars45000's Avatar
Yeah we see those from time to time in our shop... Jeep used them on the front and rear of many Grad Cherokees. Then there is a certain amount of wheel spin, the spinning side literally acts like an oil pump and hydraulically locks up, similar to a torque converter when it stalls... They actually work very well for a street driven differential
Project Family Values Build Thread
Vehicles/Projects:
-1971 C10 SWB Fleetside! Gathering parts now, will begin frame-off resto soon...
Pleasure in the job puts perfection in the work.
-Aristotle
CMars45000 is offline   Reply With Quote
Old 01-14-2009, 07:12 PM   #5
CMars45000
CMars45000's Avatar
Oh and Aluminum 44's from WJ's are a unique beast...not the same carrier as other 44's
Vehicles/Projects:
-Aristotle
