![]() Join Date: Jan 2009
Rearend swap?
I have a 67' short bed step side that I am just getting started on. I would like to convert to 5 lug from the current 6 lug setup. I have already aquired a complete 86' frame with suspension. I have the chance to purchase a rearend from a 71' GMC which has the leaf spring suspension. So I guess my question is what would my best option be keeping in mind that I would like to retain the coil spring setup. Should I use the rearend from the 86' and attatch my coil spring perches to, would the 71' rearend be better? Also would like to know if I could just swap the axles from either the 86' or 71' to the 67' housing? Thanks for any info!
![]() Join Date: Jan 2008
Re: Rearend swap?
best bet would be to sell both and buy a coil spring rear. the leaf rears dont have the track bar mount so you would have to buy or fab a mounting stud/bracket. 86 i believe is too wide, 71 is alittle wider than your 67 but would work. neither of the axles will swap into your rear.
BTW welcome from maryland ![]()
71 cheyenne lwb 300rwhp best 1/4 time so far 12.8 @103 ![]() http://i195.photobucket.com/albums/z...en58/001-2.jpg |
the boat guy
Re: Rearend swap?
im putting an axle out of a 76 in my 67, i got ccp's axle swap kit, got perches and a track bar with mounts. looks pretty easy.
67, swb, fleet, tach, throttle, 5.3, 4l60e, 3.73's, fuel cell, 5 lug, p.d.b., 4-6 drop. great little truck 66, stevens drag/ski 18' silouette, 350, 2.02 doublehump heads. comp extreme marine 278 cam, vette 7 fin valve covers, old polished edelbrock intake, velvetdrive, casale v-drive, adj cavitation plate. 28, model a rpu project, |
#4 | |
I wish I was a cowboy
![]() Join Date: Apr 2008
Re: Rearend swap?
I just swapped my C20 Eaton rear end with a 74 12 bolt. True, you do have to remove the leaf perches and weld on the trailing arm pads, and then get an adjustable/custom panhard kit (worth it anyway unless you stay at stock height). Biggest issue with using a leaf rearend is setting pinion angle correctly when you weld on the coil pads. There isn't much room for error (ask me how I know!).
-Kris Met list: Cyclone,Wilson,TranzAm,extd56,hotrodhomi,mnky30,Rokcrln,Brad,JerryJones(well, his truck anyway). Last edited by kcjones; 01-14-2009 at 05:50 PM. |
Re: Rearend swap?
Ok, thanks again for the info i'm still learning.
Re: Rearend swap?
I converted my 70 to 5 lug when i switched to disc up front and just pullled my axles and had them re drilled to 5 lug and hub shaved down at a machine shop. very easy pretty inexpensive too.
#7 | |
Re: Rearend swap?
When they re-drilled your axles did they just drill the holes or made them with the little ridges or slots whatever you call those things? I know they sell some studs that dont require the slotted thingies. I was thinking about doing the same thing but wasnt sure about the holes
'84 swb chevy '69 swb chevy '68 swb chevy '95 Impala ss-sold '89 chevy crew cab dually 3+3 Last edited by yellowGT; 01-14-2009 at 09:01 PM. |
Grandpa in the rustmobile...
Re: Rearend swap?
okay, im highly entertaining the idea of what gmc3 said, swithcin my 6 lug to 5 lug by doing what he said, can someone explain that a lil more thanks!
John Goose-1968 C10 355,9.32-1CR, Vortec Heads ,262 voodoo, 3.73:1 3OTT (HS ride/beater/farm truck) http://67-72chevytrucks.com/vboard/s...d.php?t=317684 Grams 53-1953 Chevrolet Belair http://67-72chevytrucks.com/vboard/s...=1#post4327784 1969 Chevy C10 Shortbed 4.5/6?" Frame off resto http://67-72chevytrucks.com/vboard/s...d.php?t=548136 1999 Toyota Tacoma 4x4 |
Re: Rearend swap?
is it a dangerous thing, or is it just perfectly safe?....
liek to swap to disk brakes....5 lug's cheaper...
Under Construction
Re: Rearend swap?
If done correctly by a reputable machine shop it is safe.
Heath subscribe to the board here: http://67-72chevytrucks.com/vboard/payments.php http://67-72chevytrucks.com/vboard/s...d.php?t=157669 FAQ how to's 1956 Chevy Apache 1967 C10 SWB FleetSide (under construction) 1969 K10 SWB FleetSide (Future Build) 1972 C10 SWB Stepside (Future Build) 56 chevy truck : http://www.cardomain.com/ride/2955823/1 67 truck build: http://www.67-72chevytrucks.com/vboard/showthread.php?t=281357/1 69 k10: http://67-72chevytrucks.com/vboard/s...d.php?t=389470 |
