Old 01-13-2009, 08:04 PM   #1
pokethesmot
profeshinaly unimployed
pokethesmot's Avatar
whats the best sound dampening mat
im planing on trying to make my daily driver 82 k10 a little more quite so whats the best sound dampening mat i can get but like not too expensive and does sound damping mats even work
"having mud flaps is like asking for a smaller trophy"
pokethesmot is offline   Reply With Quote
Old 01-13-2009, 08:12 PM   #2
OJOE
Crew Cut
OJOE's Avatar
Re: what's the best sound dampening mat
i had good luck with fatmat. it was 129.oo for the kit. (100sq ft) free shipping
85 SWB 1/2 TON CREWCAB/5.3
03 CHEV 3500 DURAMAX CREW CAB
85 CHEV SWB/TPI
06 CHEV TAHOE (WIFES)
30 MODEL A HOT ROD
07 HARLEY DAVIDSON BAGGER
09 STREET GLIDE
AN D A LOT MORE JUNK
OJOE is offline   Reply With Quote
Old 01-31-2010, 03:06 AM   #3
joe231
joe231's Avatar
Did you put it in the crew?
Did you do the ceiling and back wall of the cab?
Was a 100sq ft plenty to do it?
Thanks!
Oops, I just realized how old this thread is....sorry
CHEVY ONLY
joe231 is offline   Reply With Quote
Old 01-31-2010, 09:47 AM   #4
78-5.3
78-5.3's Avatar
Re: whats the best sound dampening mat
on the sound deadening for the doors do you cover the whole inside of the door skin?
78 C-10 5.3 LSX -4L60E
78-5.3 is offline   Reply With Quote
Old 01-31-2010, 07:03 PM   #5
78 Chevyrado
I covered the outer skin, the inner skin and anywhere else I coud reach to put the stuff except the very bottom of the door (don't want any rust to start). I put 2 layers on the outer skin but one layer everywhere else. I was going to do the inside of the door panels too, but I ran out. I was so amazed at the difference in the sound when you shut the door.
78 Chevyrado is offline   Reply With Quote
Old 02-01-2010, 01:06 AM   #6
GMC Guy
GMC Guy's Avatar
how much did you order? and i suppose you're pretty happy with how it came out? lol
Greg
1974 GMC
1/2 Ton SWB Fleetside
L33 5.3/4l65e
.................__
............._____l __\__
..............l_(O)_ l___(O)]
GMC Guy is offline   Reply With Quote
Old 01-13-2009, 08:19 PM   #7
78 Chevyrado
Re: whats the best sound dampining mat
I used elemental designs. It worked great and it's $1 a sq.ft. It made my cab quiet enough I have to get new mufflers so I can hear the truck again...lol Also it was very sticky, Some people said some brands can come off later on. If you don't have a roller to apply this stuff with, get one or it will suck.
EDIT, about a year and a half after the install... I had to pull the door panel off to put a new inner door handle on and all the stuff is still there, right where I left it. Tried to peel up a corner and couldn't get it.
Old 01-13-2009, 08:53 PM   #8
pokethesmot
also how much mat do you guys think i might need
Old 01-13-2009, 08:58 PM   #9
87c10slammer
truck addict
20 sqr foot if you do the floor and firewall... should have enough left for the doors also
87c10slammer is offline   Reply With Quote
Old 01-13-2009, 09:28 PM   #10
tvblazer78
Low & Fast!
tvblazer78's Avatar
B-quiet is what I used and I love it and the money is right too..
http://www.b-quiet.com/products.html
tvblazer78 is offline   Reply With Quote
Old 01-13-2009, 11:40 PM   #11
Blazer Eagle
go to homedepot and look in the roofing section, theres a product called quickroof (yellow cover, kinda small) all it is is tar and aluminun but it works great and is the cheapest thing out there, but i think only home depot has it
Blazer Eagle is offline   Reply With Quote
Old 01-14-2009, 07:05 PM   #12
dammitmitchell
the pollock
dammitmitchell's Avatar
he's correct on that one! i think it kinda smells a bit but it dosent matter after a few days
"TAC mat" it's a dense foam liner but dynamat bought them out and the craps expensive now..
i like dynamat but it's not my style..i like the thick foam stuff without an aluminum backing because it dosent reflect distortion or HI end noise...
and both (including) the home depot stuff are great and hold up well in heat
Jack of ALL trades, Master of none.. (but one... procrastination)
Army vet 02-08
RIP El Jay! Miss you brother!
http://67-72chevytrucks.com/vboard/s...d.php?t=343538
http://67-72chevytrucks.com/vboard/s...d.php?t=386042
dammitmitchell is offline   Reply With Quote
Old 04-24-2011, 11:33 PM   #13
lilpoindexter
lilpoindexter's Avatar
I used the Lowes equivalent peel n' seal..it's near the gutters. It stinks like tar, ONLY if you stick your nose in it and inhale like you were trying to snort it. It's been fine in my truck...
I was thinking about using Fat Mat...but on a Friday night, my Saturday plans got cancelled, so I said Fugg it, and ran to lowes to get it.
lilpoindexter is offline   Reply With Quote
Old 01-14-2009, 11:00 AM   #14
87c10slammer
truck addict
yeah i used somethign similar but it was to seal around the outside of window frames before you putthe siding on.. it was really jsut a thick rubber mat with really strong adhesive on it.. i accedently sealed my trunk shut on my maxima with it when i removed the rubber but left the adhesive on a hot day... it was bad but the stuff worked great when i had it on there.. 2 12" explodes and 2 1000 power acustic amps couldnt make the trunk rattle anymore
trucks
Old 01-14-2009, 03:20 PM   #15
Russell
Professional Grade
Russell's Avatar
I've heard that the stuff from home depot makes your truck smell like roofing tar once it sits out in the sun for a little while.
I'm personally going with the dynamat sound deadener.
1995 Chevrolet 2 Door Tahoe (6.6L LBZ Duramax / ZF6 / NP241 with 1 ton solid axle swap)
Russell is offline   Reply With Quote
Old 01-14-2009, 03:42 PM   #16
87c10slammer
truck addict
i didnt have any unwanted smells from the stuff i used but it only hame in rolls that where 6 inches across and i think 20 ft long.. so it was a bit of a apin to do my whole truck deck, sides and floor with but the sound quality rivalled that of dynamat for 1/8th of the price..
trucks
Old 01-14-2009, 05:05 PM   #17
hotrodhomi
hotrodhomi's Avatar
I was happy with my second skin sound damplifier.
'72 2wd blazer, bagged w/ watts link & EDC
'72 C10 "Lowered Farm Truck" STOLEN 5-18-11
'66 impala ht
hotrodhomi is offline   Reply With Quote
Old 01-14-2009, 08:56 PM   #18
Justins76
OutOfMyMind & I'llNeverKnowWhy
Justins76's Avatar
Heres a good article comparing the different brands
http://www.sounddeadenershowdown.com/
-Justin-Out of my mind and I'll never know why
1976 Chevrolet Silverado C10 350 4bbl / TH350 Big10 longbed
1986 Pontiac Firebird T-Top 5.0L TPI 700R4 WS6
1992 Pontiac Firebird T-Top 5.0L TBI 700R4
My cardomain page
I don't like to save, it's more fun to spend!!
Justins76 is offline   Reply With Quote
Old 01-14-2009, 11:20 PM   #19
chevyrestoguy
chevyrestoguy's Avatar
Justins76-
That is probably the best, most thorough independent test I have ever seen. Thank You for posting that!!!!!!
chevyrestoguy is offline   Reply With Quote
Old 01-15-2009, 12:28 PM   #20
Pyrotechnic
Pyrotechnic's Avatar
Whats everyone's opinion on gluing this stuff down ? My main concern is if water or moisture gets to it, you can't easily pull it out and dry it.
1977 GMC Sierra Grande
Pyrotechnic is offline   Reply With Quote
Old 01-15-2009, 11:32 PM   #21
andrewmp6
Give this a read before buying any http://www.sounddeadenershowdown.com/ Most of it is glued on one side and once its stuck down its hard to remove so i wouldn't worry about water.If you are worried about water a truck bed liner roll on or spray on will give you some sound deading but its water proof tho.
Old 01-16-2009, 01:32 PM   #22
TexasJeff
Don't Crush em Restore em
TexasJeff's Avatar
I have bought the Fatmat deal like OJOE, but have yet to install it. Waiting on warmer weather to finish painting my interior parts.
TexasJeff
2009 Silver with Linen Interior Cadillac DTS
1990 Red with White Top and Interior Ford Mustang GT convertible
1998 Red with Gray Interior, C3500 Chevy Crew Cab Dually
TexasJeff is offline   Reply With Quote
Old 01-17-2009, 03:01 PM   #23
copperchevy
copperchevy's Avatar
B-quiet, Hands down.
Mexican
copperchevy is offline   Reply With Quote
Old 01-31-2010, 05:30 PM   #24
thehitchmaster
thehitchmaster's Avatar
ive used cheap stuff on ebay all the way to dynamat. the dynamat in my opinion stuck to what i was applying it to better. really all your trying to do is add weight to the panel that your applying it to. made my roof on my H2 very solid.
thehitchmaster is offline   Reply With Quote
Old 01-31-2010, 10:09 PM   #25
staggerd86c-10
Squarebody Aficionado
staggerd86c-10's Avatar
any pics of you trucks getting sound deadning installed? i HATE the doors on these trucks there is no room for anything im trying to put my handles back in and door locks but it is the worse thing i have ever encountered
staggerd86c-10 is offline   Reply With Quote
