Old 01-14-2009, 06:52 PM   #1
70' GMC
HERE.......Somewhere
70' GMC's Avatar
Truck is runnin' but.....
The headlights only work on brights ONLY
Current rides: 2013 Hyundai elantra gt DD
1995 camaro my first crush lmao
Was: 1970 with a 350 4barrel and 288 horses
Classics make it possible!
70' GMC is offline   Reply With Quote
Old 01-14-2009, 06:56 PM   #2
big_al_71
big_al_71's Avatar
Re: Truck is runnin' but.....
I would check the dimmer switch on the floor check the connections or replace it, that should take care of it at least it did when mine did the same.
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-14-2009, 06:57 PM   #3
70' GMC
70' GMC's Avatar
only 3
Old 01-14-2009, 07:17 PM   #4
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Originally Posted by 70' GMC View Post
only 3
Check to see that you are getting power to the lights.
If you are, replace the lights.
If not, then the problem will either be the dimmer switch on the floor, or a wire going from the dimmer to the headlamps.
Old 01-14-2009, 07:05 PM   #5
BigDaddyDave
RIP BigDaddyDave ~7-23-09~ You will be missed~
BigDaddyDave's Avatar
I am glad its running again.
BigDaddyDave's Truck: http://www.flickr.com/photos/daves71chevy/ | See it in Action!
BigDaddyDave is offline   Reply With Quote
Old 01-14-2009, 07:19 PM   #6
oldblue1968chevy
Grandpa in the rustmobile...
oldblue1968chevy's Avatar
DIMMMER SWITCH!!!
mine did the same thing!
worked on low beam but cut off on high beam, had to drive behind gf's moms van for 10 miles home in the SNOW!
John
1999 Toyota Tacoma 4x4
Old 01-14-2009, 07:20 PM   #7
70' GMC
70' GMC's Avatar
http://shop.advanceautoparts.com/pro...pe=404&PTSet=A
Its the only one in stock is it ok cause its real cheap
Old 01-14-2009, 07:27 PM   #8
leddzepp
Moderator
leddzepp's Avatar
Dimmer switch....available at any chain parts store for less than $10
Old 01-14-2009, 07:37 PM   #9
oldblue1968chevy
yup bout 8 bucks otd
John
Old 01-14-2009, 07:52 PM   #10
697498chevy
Could also just be the lamps . My '69 lost both Low Beams .
697498chevy is offline   Reply With Quote
Old 01-14-2009, 08:15 PM   #11
cdowns
cdowns's Avatar
strange i would have thought your lights would only work on dim
Old 01-14-2009, 10:26 PM   #12
FleetsidePaul
R.I.P. E.S.L.L.
FleetsidePaul's Avatar
1971 Custom C/20
1970 CST 20
1970 C/30 Flatbed
1983 C/30 Dually
2015 Corvette Z51 2021 Corvette Z51 1991 Cadillac Hearse 1982 Cadillac Eldorado Biarritz 2000 Porsche Boxster S 2020 Jeep Gladiator 1973 VW Thing 1973 Plymouth Satellite wagon 1963 Baja Bug 1959 Bug Dune Buggy 1970 Baja Bug 1987 Jaguar XJ 350.
R.I.P. El Jay
R.I.P Jessie.
R.I.P Grumpy.
Every day is a gift from God.
FleetsidePaul is offline   Reply With Quote
Old 01-14-2009, 08:21 PM   #13
killacheyenne
killacheyenne's Avatar
dimmer switch....well thats what mine did when only my low beams worked
72 cheyenne super
83 chevy...4x4...454
killacheyenne is offline   Reply With Quote
Old 01-14-2009, 08:25 PM   #14
sbrad701
Those dimmer switches are bad about getting rust on the terminals causing a bad connection. Happened on both of my trucks. Very cheap to replace though.
sbrad701 is offline   Reply With Quote
Old 01-14-2009, 08:35 PM   #15
70' GMC
70' GMC's Avatar
just found out it wasnt that just both low, 2 park lamps, and both tail lights because of mexijapachin voltage reg stuck and blew em out Id rather pay 40 to 100 bucks for the original gm stuff instead of that foreigen crap and feed an american instead of a japachin.
Old 01-14-2009, 09:09 PM   #16
cparman
sharp as a marble
probably the dimmer switch. Many years ago me a two friends had been to Bloomington Gold a big deal corvette show. We had taken one of the guys 62 fuelie to be judged. We left Bloomington IL. about 6:00 p.m Sunday. About 3:00A.M. we were near Atlanta Ga, and I was almost awake, and I hear OH S#$%. we do not have any headlights!! I tell them to pull over. Figured it was the dimmer switch. Told the owner of this high dollar 62 Vette to open the trailer. " what are you going to do?" Me says " you will see, give me a flat blade screwdriver". So I get the short harness from the voltage regulator to the generator and make me a jumper. Jumpered the connector at the dimmer switch in the tow vehicle. It was my turn to drive, they went to sleep. Now They call me CLETIS, cause I can rig something in an emergency. Longhorn man might be right, but dimmer switches are a high fail item
cparman is offline   Reply With Quote
Old 01-14-2009, 09:23 PM   #17
1LoC10
Insert Title Here
1LoC10's Avatar
I have a hard time believing any of your posts are real.... so im not answering
BOBBY
_69 SWB_
1000 pics of 67-72's>> http://s193.photobucket.com/albums/z...-72/?start=all <<
1LoC10 is offline   Reply With Quote
Old 01-14-2009, 09:31 PM   #18
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
But his future was looking bright.....
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 01-14-2009, 10:31 PM   #19
oldblue1968chevy
lol watta story!
John
Old 01-14-2009, 11:09 PM   #20
67ChevyRedneck
67ChevyRedneck's Avatar
I thought that you were buying a gold S-10?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 01-15-2009, 12:37 AM   #21
Longhorn Man
travis... all kidding aside, this is why I told you to test it first.
You don't just throw money at a problem without troubleshooting it first.
You got lucky, it was a cheap part, and not some high dollar piece.
Old 01-15-2009, 03:06 PM   #22
70' GMC
70' GMC's Avatar
at least its only 7 bucks instead of a ben franklin
Old 01-15-2009, 04:51 PM   #23
Longhorn Man
exactly.
you got a cheap lesson on why you should troubleshoot instead of swapping parts.
