Old 01-15-2009, 12:50 AM   #1
73CheyenneSuper20
73CheyenneSuper20's Avatar
Trans fitment questions...
My th400 went out, it's behind a 454 big block... I've been looking around for a replacement, and I've been wondering...
Are all the bell housings the same? As in, a th400 bolted behind a 350 small block will also fit behind a big block? Will the 4 speed manual bolt up behind the big block with just a change in flywheel, and add the clutch? (And clutch pedal and linkage etc)
Thanks in advance....
'71 C25 Camper Special, 402, TH400, Longbed, Power Loc axle, Figuring out the rest of the details....
'10 Dodge Charger SXT - DD
'91 Kasel M101A2 3/4 ton trailer (It has Chevy rims!)
73CheyenneSuper20 is offline   Reply With Quote
Old 01-15-2009, 03:04 AM   #2
b454rat
Re: Trans fitment questions...
All Chevy V-8s have the same bell pattern. The clutch stuff too, but the 454 uses it's own flywheel....
2000 GMC CCSB 454/4L80 6” lift SAS
1999 Chevy CCSB 454/NV4500 4” SAS
1999 GMC Yukon 350/4L60 6" SAS
Old 01-15-2009, 03:11 AM   #3
Walts_restoration
Real Projects never die
Walts_restoration's Avatar
nope, one piece rear mains are different bolt pattern iirc. Also, i believe the 400s were by themselves, being they were externally balanced. But yes, using your current flywheel and torque converter, getting the correct th400 trans it will bolt right in.
Ill put it this way, ive got a few lawn ornaments
My name tag says Ryan
KansasTwister On other forums
Walts_restoration is offline   Reply With Quote
Old 01-15-2009, 07:27 AM   #4
Prong
You got the 400 engine info backwards. It's the flywheel/balancer that's different, not the bell pattern.
Prong is online now   Reply With Quote
Old 01-15-2009, 02:32 PM   #5
James McClure
One shot, one kill.
All chevy v8 engines have the same bell housing bolt paterns. Flywheel or flexplate bolt paterns change with one piece rear main seal. You could bolt a powerglide behind that 454 if you had one. Back in the 70's GM came out with what they called a "corporate case". It would fit any engine in any of the GM lines. It came in 350, 200r4, 700r4 and 400 flavors. If you have one of these hold on to it. Be aware, the clutch packs inside the tranny have fewer clutches from a 350 eng to a 454. jim
1984 K20 350M engine with 465,000 miles. Well, it's finally done!! Almost 2 years of work, but it was really worth the effort. Little stuff left to do is mount winch, wet sand & buff out and build belly pan\running boards. Body work takes lots and LOTS of beer!!!! God, Guts and Guns made America and God, Guts and Guns will preserve it! The worst thing you could do is get into my sights, but that don't matter, you'll never know it, cause you'll never hear the shotJim or Paladin whichever you choose.
James McClure is offline   Reply With Quote
Old 01-15-2009, 08:55 PM   #6
73CheyenneSuper20
Is there a difference between long tail and short tail? I have a long tail, if I get a short tail, would I be able to just bolt my long tail on?
Thanks again for all the info and experience that's on this board...
Old 01-15-2009, 09:03 PM   #7
sierra4x4
sierra4x4's Avatar
In order to change the tailshaft you have to pull all the guts out of the trans to get the tailshaft out. But it can be done.
sierra4x4 is offline   Reply With Quote
Old 01-15-2009, 09:15 PM   #8
asphaltburner
asphaltburner's Avatar
Yo! I had to do this very thing,...change out the output shaft,...to accomodate the NP205 and required spacer/mount. The TH400 came with the short shaft to mount to the NP203 due to it's SHORT spacer/mount, and the NP205s LONG spacer/mount required a long output shaft.
Wish I could tell you more about the big block to TH400 but I'm unfamiliar with the "dark side"!
Todd.
'78 3/4 ton 4x4 custom "Todd-built" FRANKENTRUCK!
asphaltburner is offline   Reply With Quote
