Old 01-17-2009, 12:57 PM   #1
Prostreet 72
Prostreet 72
Prostreet 72's Avatar
Pictures of my engine
A while back, someone asked me to post some better pictures of my engine. Here are a few I took while doing the swap. This engine came out of my drag boat. I raced quarter mile boats in a past life, and kept the engine when I sold the hull. So here are a few pictures of the mill.
Chris
Prostreet 72 is offline   Reply With Quote
Old 01-17-2009, 01:06 PM   #2
kyull67
kyull67's Avatar
Re: Pictures of my engine
sweet!
kyull67 is offline   Reply With Quote
Old 01-17-2009, 01:30 PM   #3
Hard On Parts
Hard On Parts's Avatar
Looks slow, how much horsepower? 100? 125?
Hard On Parts is offline   Reply With Quote
Old 01-17-2009, 01:46 PM   #4
shakedown96
shakedown96's Avatar
Im guessing you will use this as you commuter truck? seriously thats cool.
shakedown96 is offline   Reply With Quote
Old 01-17-2009, 01:58 PM   #5
chrislehr
Engine n00b
chrislehr's Avatar
howathreadismade.com
WOW.
Impressive.
chrislehr is offline   Reply With Quote
Old 01-17-2009, 02:13 PM   #6
big_al_71
big_al_71's Avatar
Prostreet, that is a serious looking motor of course looks could be
deceiving (J/K)
Did you install it in the truck already?
What is the compression on it? 11:1, 12:1 etc
Get your facts first, and then you can distort them as much as you please!!!!!.
Sylvester's build thread >>>http://67-72chevytrucks.com/vboard/s...ht=big+rebuild
big_al_71 is offline   Reply With Quote
Old 01-17-2009, 03:19 PM   #7
60ratrod
yes, i do
60ratrod's Avatar
my question is what is the purpose of running a line from the fuel pump mounting area to a catch can?
60ratrod is offline   Reply With Quote
Old 01-17-2009, 05:46 PM   #8
theyammieguy
accepting donations
theyammieguy's Avatar
Some kind of breather.
1999 Yamaha roadstar 1600 chop. (in progress.)
See my builds here>http://s113.photobucket.com/albums/n238/nickrp_2006/
"Ya'll can go to hell, I'm going to Texas."
David Crockett
theyammieguy is offline   Reply With Quote
Old 01-17-2009, 06:11 PM   #9
Chevymann1968
Chevymann1968's Avatar
That Might be an ice can!!!! I ahve seen something like that !!! you put ice in it to keep the fuel cool!!!
By the way !!!!
1968 GMC
Rebuilding Stage
2001 Camaro SS SOLD
Chevymann1968 is offline   Reply With Quote
Old 01-17-2009, 05:44 PM   #10
thirdstreettito
Resident of Here
thirdstreettito's Avatar
Sexy DD engine.
~Bradley~
2004 Black GTO LS2/T56 too much to list
Miss having a truck
thirdstreettito is offline   Reply With Quote
Old 01-17-2009, 06:06 PM   #11
Kayotic
Kayotic's Avatar
Keep looking, I am sure you can find a good used 350 in your area.
Yikes!
- Are you gonna tell us some specs on that beast?
Sure is pretty.
Kayotic is offline   Reply With Quote
Old 01-17-2009, 07:15 PM   #12
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
I was gonna ask about the breather can and it's plumbing too.
chevyman... there's no fuel pump, nor fuel line.... it's not an ice can.
Old 01-17-2009, 07:27 PM   #13
R.L.
R.L.'s Avatar
That's impressive!
R.L. is offline   Reply With Quote
Old 01-17-2009, 07:45 PM   #14
retodd7711
chrome makes it go FASTER!
retodd7711's Avatar
Definitely need pics of that puppy in your truck!
She can't cook
and she won't clean.
But she looks good in a skirt
and she brings me beer.
She can stay for now.
EDIT:: But she left me anyway,
So forget her.
1962 GMC Stepside V6 4 speed
My rolling resto thread
http://67-72chevytrucks.com/vboard/s...d.php?t=324226
My old farm truck
http://67-72chevytrucks.com/vboard/s...=1#post3465005
retodd7711 is offline   Reply With Quote
Old 01-18-2009, 01:59 PM   #15
Prostreet 72
Prostreet 72
OK. The first time I saw this set up I asked the same questions. I found this set up in an issue of fastest street car. There is a company that sells this evac kit. I made my own, because he wanted too much for his. The idea is that heat rises, along with vapor and condensation. This gives the vapor a direct path out of the engine straight from the origin. The crank case. Since I do not use a mechanical fuel pump, there is no push rod or anything in this location to disrupt the flow of vapor. This system acts as a chimney, for a lack of better discriptions, to vent the crank case. To help add to the system, the breather tank with the flow thru element create a vacuum as the air passes thru the element. So what happens is the condensation gets cought in the can, and the vapor escapes. It sounds far fetched, but it dose work. I ran this on the boat when I was racing, and the can would fill up with water after a day of running. Of course, on the boat the lake temp kept the engine from getting hot enough to burn off the condensation. So there you have it.
I attached a few pictures of the engine in the truck, as well as some while in the process and of course, the boat. The engine made 690hp on the dyno when it was built. ( 8 years ago) Now, who knows. It still runs strong, and has no oil burning issues, but this engine was very well maintained throught the years. Before it went into the truck it was freshened up a bit.( Gaskets, oil pump, heads rebuilt, rockers replaced, and roller lifters rebuilt) It seem to run fine. Actually, the first time on the road hammering it, I felt like I was driving the boat again. Same sound, similar acceleration pull. The boat ran in the 10sec brackets, so it pulled on a scary level. Small spec for you, at 6000 rpm, the jet pump pushed 1000 gallons per second. The picture showes it hanging from the scales at a current boat manufacture while we made so mods to the hull and pump. By the way, it weighed in at 1500 lbs with 13 gallons of fuel on board.
So there it is.
Old 01-18-2009, 02:42 PM   #16
60ratrod
yes, i do
60ratrod's Avatar
oh ok. well i knew that the little crackerjack toys aka over-grown riding lawn mowers on steroids run them so the oil vapors don't get sucked back into the motor. i was just wondering why run one from the fuel pump boss on the motor. thanks! that thing does look dead friggen sexy though!
Old 01-18-2009, 08:24 PM   #17
Prostreet 72
Prostreet 72
In the truck, it is sort of in retirement. I don't run it that hard in there. A street race or so, mabe a good burn out to get my fix, but that's about it. I love that thing! I have had it since I graduated from high school in 91. The truck that is. When they kick the dirt in around me, they can figure out what to do with it.
Chris
Old 01-19-2009, 07:14 PM   #18
heavy71chevy
heavy71chevy's Avatar
That is one bad mofo!
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
Old 01-19-2009, 11:52 PM   #19
72 SUPER10
Damn
72 SUPER10 is offline   Reply With Quote
Old 01-20-2009, 12:01 AM   #20
LuckyHenriksen
LuckyHenriksen's Avatar
That is a sexy ass motor. I love it
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 01-20-2009, 12:25 AM   #21
Drobny
Hunting is Life
Drobny's Avatar
1970 GMC K-1500 4x4 292 I-6 3 on the tree-prodject truck
1971GMC 2500 2wd 350-v8 sm465 4spd-parts truck
2005 Ford Ranger 4.0/5spd auto 4x4 extended cab--everyday driver bought new
Drobny is offline   Reply With Quote
Old 01-20-2009, 01:47 PM   #22
MickMc
MickMc's Avatar
The boat looks like a California Performance or maybe a Texas Tunnel, maybe...
Mick
MickMc is offline   Reply With Quote
Old 01-20-2009, 01:56 PM   #23
Prostreet 72
Prostreet 72
Mick
Very close. It is a 1984 Mantra Gullwing with a pro-race Dominator jet pump.
Chris
