Old 12-08-2002, 06:05 AM   #1
PhoneTruck
Question What Size?
I bought a 1967 1/2ton Southern Bell 2 speed pick-up with 6 lug 15" rims and the speedometer is approx. 7 miles fast! Can some please tell me the wheel and tire size that the fleet truck came with? Its a 2 speed,so I would like to get the correct size because I believe it would lower R.P.M. also!
PhoneTruck is offline   Reply With Quote
Old 12-08-2002, 12:22 PM   #2
ChevLoRay
Old Skool Club
ChevLoRay's Avatar
I imagine the stock size tire in '67, for a half-ton truck was either a 6.70, or a 7.10, maybe even an 8.00X15.
Then, there were the 7.75 series that came out.
Your tires would have to smaller than the original size to cause your speedometer to be overly optimistic. The gear in the transmission tailshaft that drives the speedometer may not be correct. The gearing in the differential may not be the one that it left the factory with. Oh, one more thing....mechanically-driven speedometers of old were notorious for being inaccurate. Yours may be just like it always has been, which is why the police had "Certified" speedometers in their vehicles.
Electronics has provided us with accurate speedometers, especially since so many factors for the engine computers are dependent on the speed of the vehicle, for one of the inputs.
Mine is pessimistic, by approximately 5MPH, when I am going approximately 65MPH, i.e, it shows me to be doing 60MPH, more or less, or thereabouts. So, I kinda rely on "Pacing" to keep me in check, or out of trouble.
So, bottom line, having the original size of tire may not provide you with the accuracy you want. In fact, it may be difficult to achieve without taking your speedometer to a shop that specializes in them and can certify it, knowing your axle ratio and the gear in the transmission that drives it.
Member Nr. 2770
Old 12-08-2002, 12:40 PM   #3
Capitol68
Capitol68's Avatar
mine had 16" orig.
'68 Fleet LWB
orig 307 .030 over
GM Hei/w Accel Super coil
orig. stock TH 400.
_______________________
“What we do for ourselves dies with us. What we do for others and the world remains and is immortal.”
Albert Pine
English author d.1851
Capitol68 is offline   Reply With Quote
Old 12-08-2002, 09:04 PM   #4
PhoneTruck
Thumbs up Capitol68
Thanks guys for your help and Capitol68 what was the tire size of the 16"? Thanks again!
Old 12-09-2002, 11:08 AM   #5
67/72junkie
speedo
Ride behind friend with vehicle known to be correct to find out how far youre off. Remove speedo gear from transmission and count teeth . Each tooth added or subtracted is approximately 5 mph . Two or three bucks at gm parts counter.
67/72junkie is offline   Reply With Quote
Old 12-09-2002, 11:19 AM   #6
Southpa
Southpa's Avatar
I guess that goes for the odometer too. Hmmmm...maybe thats why I'm only getting 7.4 mpg... tires are 31" high.
1970 GMC 1500 Custom
Original 350/TH350
Victoria, BC, Canada
You can wish in one hand and crap in the other.
See which one gets filled first.
Southpa is offline   Reply With Quote
Old 12-09-2002, 12:33 PM   #7
Capitol68
Capitol68's Avatar
I dont remember what was on it before,friend had it before me,He changed to 15',with 10 x 31.5.\
I found you drive next to one of those new fangled vehicles with electronic display, you can look in their window and see that way.I think mine is off like 5 mph
'68 Fleet LWB
orig 307 .030 over
orig. stock TH 400.
Albert Pine
Old 12-09-2002, 11:32 PM   #8
PhoneTruck
Thanks all again!
Thanks to all of you that have responded to my question. I think now that it did come with 16" wheels and it is not all the speed thing of 7 miles per hr. faster with the 15" instead of the 16".but I was thinking the engine R.P.M. would also be lower running the larger wheel by several hundred. What do you think? Thanks again.
Old 12-10-2002, 12:39 AM   #9
Longhorn Man
its all about the +6 inches
Longhorn Man's Avatar
Look in your glove box. There should be a sticker that will read 16 inch rims if it was so equipped.
Old 12-10-2002, 01:04 PM   #10
PhoneTruck
No Glove Box
The glove box was missing,but thanks anyway. I was hoping someone had a 67 GMC Owners Manual that might list the size!
Old 02-27-2003, 01:35 PM   #11
solidaxel
solidaxel's Avatar
Count the teeth on the speedo gear ( in the side of the transmission) like he said and go to one that has 2 teeth less!
53 TuTone Extended Cab 350 4-Spd 3:08 (SOLD)
53 Chevy Moldy pearl green ZZ-4 4L60E 9" 3:25
55 GMC 1st Black Mll (ZZ4) ZZ6 TKO 600 5 sp 3:73
62 Solidaxle Corvette Roman Red (327
340hp 4spd 3:36) C4 & C5 suspension tube chassis
LS 3 4L70E
65 Corvette Coupe 327 350hp 4spd 4:11
78 Black Silverado SWB (350/350) 5.3 & 4L60E 3:42
2000 S-Type 3.0 (wife cruiser)
2003 GMC SCSB 5.3 4L60E 3:42
solidaxel is offline   Reply With Quote
