Old 12-08-2002, 12:06 PM   #1
kaycee
kaycee's Avatar
Talking Whack Off In The Garage
I was going to whack off a few inches off my front springs.Does any one have the rule of thumb as to how much to cut to get a 2" drop.I know the hazards of going this route but I like living on the edge.
2001 Silverado K-1500
2005 FXDWG stage3
69 CHEVY Short/Step 327/4L60 373 posi
63 IMPALA 327/4L60
kaycee is offline   Reply With Quote
Old 12-08-2002, 01:18 PM   #2
SCOTI
SCOTI's Avatar
You can always cut more, but you can't put it back so start w/about 1/2 coil. Try it & if more is needed cut another 1/2. My 68 has 2.5 drop spindles w/1 coil cut for about a 5" drop up front.
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 12-08-2002, 01:27 PM   #3
HIGH724X4
I'D LOCK THE DOORS!!!!
72 CHEVY FLEETSIDE 4X4 K10
(SOLD TO JAMIE72,
BUT BLAZER GAL PULLED AWAY WITH IT LOL!!!)
Will Own one Again!!!
1967 CAMARO (PRO-TOURING PROJECT)
Lawrenceburg, Indiana..
AOL IM: kbillcad
HIGH724X4 is offline   Reply With Quote
Old 12-08-2002, 01:46 PM   #4
Downtown
Downtown's Avatar
Lightbulb
I put a new set of front coils in my 71 shortbed with a 350. I cut off 1 coil and it dropped the truck 2'' measuring from the top of the wheel well. I also think it is better to start off cutting 1/2 coil at a time. It is a real bummer to put spacers in a new coil because it dropped too much.
72 Super Cheyenne Longbed 350 49,000 original miles and My dad ordered it new
66 Chevy Caprice 2 dr
77 Caprice Estate Wagon
New Palestine, IN
Downtown is offline   Reply With Quote
Old 12-08-2002, 01:53 PM   #5
crazy longhorn
Fabricate till you "puke"
Whackin off in the garage......maybe you should see if one of the neighbor gals will help you! I cut 1 full ring off my coils, & figure about 2 1/2 - 3 " drop(depending on lite or heavy spring), & i noticed that they settle in a bit after use. IMHO, if you are going to cut em, you may as well take 1 full ring ,so that the springs seat properly on both ends. When I cut mine, I dumped them upsidedown in a 5 gal bucket of water & cut the exposed end. You will also need shorter shocks,or custom brackets to run the stock lenght shock(mine are fabbed brackets), but I think Turner enterprises has front shock brackets for about $45. I cut the bump stop brackets off the a arms (left the steer stop), & use traction bar snubbers for the bump stops. Good luck......crazy AL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 12-08-2002, 03:48 PM   #6
low 84
low 84's Avatar
do they have a web site? i would like to check those front shock extender brakets out.
i would even go less than a 1/2 coil at a time. i would go 1/4 coil at a time and let them settle a while before you cut more off.
'51 F100, backhalf with a narrowed 9 and coil overs, 18.5" mickeys, monte front clip, +400" sbc in the works
'05 1500 Crew Cab
RIP
'84 swb 5/7 drop, solid cammed 408 w/ fully ported dart heads, th350 w/ 10 inch hughes, 12 bolt w/ 3.73 richmonds and a locker
'80 swb 4x4 in progress: 7" lift, 350 th350/np205, d44 and 1.5" ORD tie rod, 14BFF w/discs , armored diff covers, 40" MTR's
low 84 is offline   Reply With Quote
Old 12-08-2002, 03:55 PM   #7
crazy longhorn
I couldnt find a web site Low 84, just an add in the back of Jan issue of street trucks. Phone # 909-926-1729
Old 12-08-2002, 07:09 PM   #8
low 84
low 84's Avatar
thanks crazy L, i will give them a call. how do they work? do they extend the bottum mount down, or extend the top mount up. thnx
'05 1500 Crew Cab
RIP
Old 12-08-2002, 07:50 PM   #9
crazy longhorn
They extend the top mount, the bracket bolts to the top of the frame. They also have some other nice lookin pcs, if you find they have a web site I would be interested to take a look.....
Old 12-08-2002, 08:55 PM   #10
low 84
low 84's Avatar
ohh that is cool. i would actauly like to use it on my '84, do the 67-72 ahve the same kind of front shock mount? bottum bolts to the back side of the control arm and top bolts to a stud on the frame? i can't remember how it was on my other truck. thxn, sorry to bug you so much
'05 1500 Crew Cab
RIP
Old 12-08-2002, 09:04 PM   #11
crazy longhorn
Yup, same setup
Old 12-08-2002, 09:18 PM   #12
stllookn
Saving 1 truck at a time!
stllookn's Avatar
I cut one round out of my front springs and it lowered my truck 2-3/8 inches. It is a 1967 C10 with a 305 and TH400.
'68 C20 Longhorn 50th Anniversary 400/TH400
'68 C20 Longhorn 50th Anniversary 468/TH400w/buckets
'72 C20 Halfhorn (Longhorn w/o cab and front clip)
'69 Flxible Cruiser (look up ugly in the dictionary)
stllookn is offline   Reply With Quote
Old 12-08-2002, 09:45 PM   #13
crazy longhorn
Stllookn,have you put many miles on the truck since cutting the springs?
Old 12-08-2002, 10:33 PM   #14
kaycee
kaycee's Avatar
Thanks everybody think I 'll go for 1/2 a ring first.That was a catchy title wasn't it?
2005 FXDWG stage3
63 IMPALA 327/4L60
Old 12-08-2002, 10:35 PM   #15
BIG ORANGE
BIG ORANGE's Avatar
Thumbs up
I agree with downtown and stlookin on the rull of thumb for whacking off the front spring they are correct if you have V8 springs to start with.
Things happen for a reason!
BIG ORANGE is offline   Reply With Quote
Old 12-08-2002, 10:55 PM   #16
Nelson
Use a Big Block.
Nelson
1970 C10 350 Auto.
A/C not Working
Nelson is offline   Reply With Quote
Old 12-08-2002, 11:27 PM   #17
crazy longhorn
Yes, depending on lite or heavy spring, the drop will be a little different. In my case, I used the lightest set of (new) stock springs i could get. They also did settle in a bit after driving the truck........id say Im right at 3" on the drop. Another thought is that a new spring take a little run time to settle,whereas if you cut an old spring it may already be sagged 3/4"....... I still think to seat the spring properly in the arm, & also the top pocket......it should have 1 FULL ring taken off to locate it the way it should be(that way it cant move around in the pocket). Good luck...crazy AL
