advice
i have a 1972 international 1210, basically a f250. it has a dana 44 rear end with 3.96 gears and i just wanted to get some opinions on how i can get some better mileage.
Engine 345 CI 2bbl 500 CFM carb 3 speed C6 tranny LT245/85/16 tires any ideas? any help wold be aprecaited |
Another Day, Another Dollar
Re: advice
are you primarily driving highway or city?
-78 K20 Cheyenne 454 long box, 4" lift, 35" MT's, '84 cab, '80 box "its hip to be square" ![]() |
Re: advice
mostly city but i do some freeway
Re: advice
I had a '73 caprice with a 400 in and a 2bbl carb. Dumb as this sounds, I got better mileage after I put a 4bbl on it. Lower (numerically) rear gears will help mileage.
Re: advice
what kind of gears would u suggest?
how big of a 2bbl was on before and after with the 4 bbl |
Sb 400 club
Re: advice
I have heard the same about 4bbl and better fuel millage. I am not sure exactly why as the secondaries would consume more fuel when open but maybe the primaries are smaller then that on the stock 2bbl so maybe it is more efficient??
![]() ![]() 77 K10 Project / daily driver "The Grinch" http://67-72chevytrucks.com/vboard/s...d.php?t=318363 1956 Willys Wagon (327 chevy) Project (Now Buick 225) 1980 Corvette L-48 4 speed 1992 Mustang GT built 5.0 5 speed ![]() 1985 C10 LWB Sold 1982 K10 SWB plow truck Parted out 1986 D30 M1028 fire brush truck Parted out |
Re: advice
To the best of my knowledge (and I wouldn't put any bets on this!) a 2bbl carb is larger than the primaries on a 4bbl carb. So in theory if you keep your foot out of it you will get better mileage.
2009 Honda Fit CfC (bsf 44.9 mpg) 2000 Tahoe Limited 1991 GMC CrewCab Dually 2wd, will end up swb, not dually and replace CCswb below 1991 GMC CrewCab Dually 4x4, just going to fix things up for now 1982/1989 K5/GMC Jimmy 2wd 1987 GMC 1/2 ton swb 2wd Crew (sold) |
#8 | |
![]() Join Date: Jul 2003
Re: advice
You have to remember that a 3/4 IH pickup is a heavy duty pickup and gas mileage was not there (IH) main concern. One thing to consider doing is converting to a pertronix electronic distributor. My IH runs way better than when it had points and condenser. And truthfully, setting the points on a IH just plain sucks. |
Re: advice
What size carb would you suggest and whay else would I have to change
Re: advice
I think you are asking a lot from your IH. The 345 IH motor is basically a truck motor and is designed to lug. Trust me, I have one in a grain truck and it will pull like a freight train but eats gas, I'm lucky if I get 5 MPG. Changing the rear in will help a little and the 4 barrel might also help.
Weight is also a problem, a 345 IH motor weights 641 lbs without accessories, more than a big block chevy. |
Re: advice
An Edelbrock 650 would be a decent carb for it. You would need a new intake manifold to go to a 4 barrel though.
Headers, and a free flowing exhaust will also help. Again, I'm not sure about the availability of headers for these trucks. If your existing exhaust is restrictive, a new true dual exhaust with an H pipe and some free flowing mufflers could help. Also, a free flowing air cleaner with a cold air source can also help.
1977 GMC Sierra Grande |
Re: advice
I have true dual from manifold back
What kind od fuel increase would I get.all I really need is 2-3 mpg |
Re: advice
Re: advice
where do i get the distibutor and how di set them?
