01-24-2009, 02:44 PM | #1 |
Engine RPM's
My truck has a 305 with the stock Quadrajet on it and a 4spd transmission.
When I drive a vehicle with manual transmission I sort of expect the RPM to drop back to idle speed as soon as the clutch is disengaged. On my truck however when I disengage the clutch (depending on how fast im going, what gear im in, and engine temp) the engine will rev way up for a few seconds then settle down to idle. Couldnt tell you what it revs to as it dosent have a tach but I imagine 2500RPM or so. It happens the worst when the engine is cold and im only doing 25mph in 2nd gear and come to a stop sign or something. Anyone have ideas on why it would do this?
Its no disgrace being poor. Its just inconvenient. |
01-24-2009, 07:42 PM | #2 |
The One And Only !!!
Re: Engine RPM's
It sounds to me that you could have a vacuum leak somewhere, Maybe a loose/cracked vac. hose or possibly intake ?
93 Jeep XJ 88 Buick La Sabra Toys; 88 TA-GTA in the works.... 97 GMC Ext. Cab 502 Crate 5 Spd......Sucks Gas But Haulz Azz ! The primary function of an Engineer is to make it difficult for the Fabricator and impossible for the Mechanic. "Why go out preserved when you can go out beat up, worn out, sliding in sideways screaming, Holy Sh!t What A Ride" !!!
01-24-2009, 09:12 PM | #3 |
Parts and more parts
Re: Engine RPM's
It sounds like your carb throttle shaft is hanging up and not returning to idle position, when you relieve the load on the engine. Take a look at your throttle return spring and see if it is not too weak, or maybe the carb has worn bushings in it and the shft is hanging up there.
01-25-2009, 09:50 AM | #4 |
Re: Engine RPM's
Ill take a look and see about both of those
Thanks guys
