01-27-2009, 10:28 PM | #1 |
Oh no!
well i got a problem. i cut off the bottom door pillar to replace it and the little door backer plate fell out no biggie. any how i got tied up doing something else and left it for the day , the next day while in the garage i noticed my 3 year old playing with the plate so i took it and put it on the shelf. well that after noon i thought about it and decided i should tack it back in before it got lost and guess what its no where to be found. so if any one has one or can get one i would gladly pay for it. right now im to a point where i need to bolt the door on so that i can line up the rocker and install it
The Ghost 67 short wide full custom. 550 hp LSX, 4l80E, narrowed 9". Body dropped w/air ride! ........................ ___ .........________//__{\_____ ,,,,,,,/__(⊙)___//___/__(O)_/ @disciple2.rc 💪instagram💪 LED TAILS |
01-27-2009, 11:49 PM | #2 |
Resident of Here
Re: Oh no!
Dont know if it is a repro'ed part. When you get it you will find the other one. It always happens!
~Bradley~ 2004 Black GTO LS2/T56 too much to list Miss having a truck |
01-27-2009, 11:57 PM | #3 |
Re: Oh no!
Don't you just love when you put something somewhere it won't get lost then bam it's lost anyways.
00' Z28 ("wifes" car) 92' Mustang w/sbc everything needs a little heart beat 87' GMC Sierra Classic Short Bed Fleet side almost stock 69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it |
01-28-2009, 12:08 AM | #4 |
Re: Oh no!
You talking about the plate on the hinge side? (because I don't remember if there is a plate on the striker). Upper lower are they the same?
01-28-2009, 07:06 AM | #5 |
Re: Oh no!
post a pic of what u need if possible i most likely have one if u will pay for the ride u can have it
01-28-2009, 08:16 AM | #6 |
Spanked once
Re: Oh no!
In a pinch I guess you could get a piece of 12 ga; or better to make a plate ,drill and weld nuts behind it.
The ole 350 budget build. |
01-28-2009, 10:58 AM | #7 |
Spanked once
Re: Oh no!
In the picture i tried to make an arrow to show a slot I made in the piller with a cut off wheel that I welded a strip of sheet metal to the plate to hold it loose but in place till my door is aligned and then I will weld the tab in place.
01-28-2009, 11:49 PM | #8 |
Re: Oh no!
I don't have a problem welding one in , i already done the other side but i have to have one to weld in there. it is the drivers side lower door hinge plate
01-29-2009, 02:54 PM | #9 |
Re: Oh no!
Got one - Threads are good.
