01-29-2009, 02:22 AM | #1 |
00 chevy 3500 eletrical problems need help
my 2000 chevy 3500 work truck has no power at the heater fuse and the anti lock brake lite turns off and on when it wants and there is a buzzer that goes of every once and a while. any one every experince this and what was it. thanks
vinnie 1960 chevy c10 frame with a 1966 cab 2002 dodge intrepid r/t 2004 chevy 2500 4 door short bed |
02-02-2009, 02:20 PM | #2 |
Re: 00 chevy 3500 eletrical problems need help
sounds like maybe an intermittent ground or ABS sensor. or a combination of things. check out the ABS sensors located on each front hub. chek for corrosion or broken wires.
check the under hood fuses and any exposed wiring for damage, let us know what you find.
Andy... '70 C/10 Under Construction http://67-72chevytrucks.com/vboard/s...d.php?t=298553 '71 K/20 Frame-off resto, SOLD!!! http://67-72chevytrucks.com/vboard/c...ct=2399&cat=12 '05 Silverado Z-71, CC SB, Daily Driver |
02-03-2009, 01:04 AM | #3 |
i will check those out and let you know what i find. thanks
02-23-2009, 09:13 AM | #4 |
There is a small ground wire on the rear passenger side of the engine that comes out of the harness and is secured to the rear of the block with a bolt. Disconnect the bolt, clean the surfaces and re-install. This solved the electrical issues I was having with my 2003 Sub. It may or may not help with your problem but it may be worth the effort.
03-06-2009, 12:46 PM | #5 |
well i found the problem it was the ignition switch the orange wire coming out of the switch that powers fuse # 6-12-18-24 fuses was getting no power. replaced ignition switch and all works again. thanks for the help guys
