Old 01-30-2009, 12:45 AM   #1
KMACD71
KMACD71's Avatar
Having a problem installing a new steering wheel
I'm putting a new steering wheel on, and am curious as to how much the shaft should move in and out.Mine moves about a half inch.I need that half inch to get the nut back on and enough of the new adapter to seat in the splined shaft.If this movement is normal,how do I keep the shaft from moving back down when I put the plastic canceling cam and adapter on the shaft?Any advice would be appreciated.Thanks.
KMACD71 is offline   Reply With Quote
Old 01-30-2009, 09:25 AM   #2
mole2000
mole2000's Avatar
Re: Having a problem installing a new steering wheel
you mean the shaft moves up and down the column length? i dont think it should do that. i just installed rebuilt tilt column and mine has some slight side to side movement, but no vertical.
mole2000 is offline   Reply With Quote
Old 01-30-2009, 10:21 AM   #3
KMACD71
KMACD71's Avatar
Yes,It moves up and down.I did a search on previous threads on here and there was some advise on pulling the shaft out to get the room you need to get the wheel back on properly.My problem is the adapter hub seems to push i back down.
Old 01-30-2009, 04:19 PM   #4
mole2000
mole2000's Avatar
I just checked and mine has virtually no vertical play. I did have to push the parts together due to the springs involved. I also have an aftermarket wheel, but the amount of play shouldnt affect that...
Old 01-30-2009, 09:39 PM   #5
KMACD71
KMACD71's Avatar
Thanks for checking.My column isn't a tilt like yours is, so maybe there is a difference. Anyone else want to weigh in on this. Thanks.
Old 01-30-2009, 06:04 PM   #6
heavy71chevy
heavy71chevy's Avatar
mine does that...Im replacing the colomn for a floor shift but I fugured it was just plain broken
"Dixie Destroyer"
71 C10 LWB Fleet
Future Blown Prostreet Monster
heavy71chevy is offline   Reply With Quote
