01-30-2009, 11:46 AM | #1 |
control arm bushings
71 c10 rear coil, Going to replace the contol arm bushings, is it as easy as un-bolting the cotrol arm, letting it drop and replace the bushing and bolt it back in or am I in for something I dont know about and I need to block out a whole day, any advice on the best way to do it and do I need to jack it up or do it on its wheels, thank you, pics comming when I can figure out this whole computor and digital camera thing
01-30-2009, 02:22 PM | #2 |
Re: control arm bushings
I had one truck where they came right out & another where I struggled w/them all freakin day. I do the bushings on a bench-top because I spot weld the 'halves' of the arms together which is easier in the open vs. laying under the truck.
If there's a bunch of rust on other suspension components, expect delays.
67SWB-B.B.RetroRod 64SWB-Recycle 89CCDually-Driver/Tow Truck 99CCSWB Driver All Fleetsides @rattlecankustoms in IG Building a small, high rpm engine with the perfect bore, stroke and rod ratio is very impressive. It's like a highly skilled Morrocan sword fighter with a Damascus Steel Scimitar..... Cubic inches is like Indiana Jones with a cheap pistol. Last edited by SCOTI; 01-30-2009 at 02:25 PM. |
01-30-2009, 02:43 PM | #3 |
some people have actually burned the bushings out with a torch. You will need to get all the residue out if you do this. They can be a real pain but like Scoti said they are not always a problem.
Dave
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
01-30-2009, 03:14 PM | #4 |
I do not recommend the torch method. I tried that on my first attempt & all it did was make a huge mess. Black soot was everywhere.... the floor, walls, hands, clothing..... you name it. In the end, I still had to press them out on the bench (these were the ones that required messing w/all day).
01-30-2009, 06:20 PM | #5 | |
Fabricate till you "puke"
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears.... |
01-31-2009, 12:23 AM | #6 | |
01-31-2009, 06:23 PM | #7 |
Yup ,its a nasty job any way you do it! I have ate more of the smoke off those old bushings than a halve dozen guys should see in a lifetime(Illinios salt) Anything that "whizzes" this old man off , gets to play with the "fire stick" My old longhorn was a west coast truck.......that was real sweet to play with, brush the dirt off the bolts & unscrew them crazyL
01-30-2009, 05:10 PM | #8 |
I've never succeeded in pressing them out even with a 5 ton press. I've always gone for the burn 'em method.
