Old 01-30-2009, 11:39 PM   #1
westbrookw
LET'S GO...MOUNTAINEERS
westbrookw's Avatar
New valve covers...
What do you think? I got a set of Holley covers to match the carb. Plus the Edelbrocks were too tall. These things were oxidized bad, but a friend of mine at work did a hell of a job.
72 SWB/Step
westbrookw is offline   Reply With Quote
Old 01-31-2009, 08:42 AM   #2
Andy4639
Old member
Andy4639's Avatar
Re: New valve covers...
They look cool, but don't you think they would leak less with the hold downs and gorments in place!
Seeing the USA in a 71
Upstate SC GM Truck Club
http://upstategmtrucks.com/
Old 01-31-2009, 09:48 AM   #3
Sport/Truck
Sierra Grande Club
Sport/Truck's Avatar
Will these clear the stock alternator on the drivers side? Is that what was wrong with your taller ones?
s/t
1971 GMC Sierra Grande, 1/2 ton short wide, original 4 bolt 010 020 block & heads. (matching #'s). 383 stroker, SMI q jet 750 cfm, Lunati Voodoo 60102 cam, Scorpion roller rockers, Spin Tech pro street mufflers with X pipe.
Sport/Truck is offline   Reply With Quote
Old 01-31-2009, 10:32 AM   #4
westbrookw
westbrookw's Avatar
s/t
Alternator is on passenger side. The Edelbrocks worked, just didn't like the height.
72 SWB/Step
Old 01-31-2009, 12:18 PM   #5
Sport/Truck
Sierra Grande Club
I don't think the tall covers have an issue on the long water pump/ passenger side.
I'm just trying to find my own answer to what will/wont work on stock alternator setups. No high jack intended.
s/t
Old 01-31-2009, 09:59 AM   #6
bignbad
bignbad's Avatar
what kind of header do you have?The lettering is to small to read on the tag in the picture.
'72 chevy k20
'06 H-D Springer softail
http://www.bluemooncruisers.com/
http://www.enginecycle.com/
~Eric
bignbad is offline   Reply With Quote
Old 01-31-2009, 10:33 AM   #7
westbrookw
westbrookw's Avatar
Doug Thorleys
72 SWB/Step
