weatherstripping installed, what did i do wrong??
ok, well i aligned my doors with the body lines before putting on the new weatherstripping arond the doors on both sides. after it was dry enough i tried to close the doors and it gets to the first click somewhat easy, but wont shut on its own with minimal force, the only way to get the door completely shut, 2 clicks, is to almost slam it... and it looks like the new gasket is being smushed on the inner part of the door right at about dashboard height... what is up with these gaskets? i got the ones from wes at classic heartbeat and lined them up perfectly when i put them on, they follow the lines exactly, and moving the doors out farther isnt an option because they are already lined up with the body panels... do they just need to wear in more on their own?
Active Duty Navy / Part time wanna be hot rodder? 89 Cressida w/ 408hp/674tq (with lots of wiggle room) ![]() 69 C-10 Project http://67-72chevytrucks.com/vboard/s...=1#post3066994 |
Moderator
![]() Join Date: May 2007
Re: weatherstripping installed, what did i do wrong??
did you use the glue-in type, or the press on kind?
glue in type, with super weather strip adhesive
![]() Join Date: Nov 2004
They will soften with time. I've always had to give my doors a good shove to close when the windows are up.
They will be stiff for a while. And that area by the dash.... just never seemed to be a good design to me either... Roll down the window and try to close it, it probably closes easier?
Jesse James 1967 C10 SWB Stepside: 350/700R4/3.73 1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc 1968 Pontiac Firebird: Project Fire Chicken! 2015 Silverado Double Cab 5.3L Z71 2001 Jeep Wrangler Sport 4.0L 5spd 2020 Chevrolet Equinox Premium 2.0L Turbo 2011 Mustang V6 ~ Wife's ride ![]() American Born, Country by the Grace of God ![]() 1967 CST Shop Truck Rebuild! My 1967 C-10 Build Thread My Vintage Air A/C Install Project "On a Dime" Trying my hand at Home Renovation! 1965 Mustang Modifications! |
#5 | |
Resident of Here
~Bradley~ 2004 Black GTO LS2/T56 too much to list ![]() Miss having a truck ![]() |
![]() Join Date: Dec 2008
I saw pics on here of a guy taken the strikers off the cab and using a bunge cord to hold the doors shut slightly past closed and that seemed to work rather good after a few days.
00' Z28 ("wifes" car) 92' Mustang w/sbc ![]() 87' GMC Sierra Classic Short Bed Fleet side almost stock 69' Chevy short step carbed 6.0 w/400th trans. Completed w/325 miles on it |
thanks guys, good to know that its normal for the gaskets to have to wear in to close properly later, ill probably just leave the doors shut all the way for a while before getting ready to paint the exterior now.
"Trucks with Class"
![]() Join Date: Jul 2000
You are just going to have to wait and see if the rubber compresses enough to eventually let the doors close more easily.
Remember, you adjust the doors & seals first, then you align the fenders. Everything lines up with the doors...even the rockers, if you are replacing them. |
#9 | |
Thus is so true to bad the person who put the rockers on my truck didn't quit figure that out till after he welded the new ones in.......... ![]()
They may never close as they did; new w/strips have too much eurathane(?) blended in the rubber to compress enough to close smoothly.
it might be doing this since its cold out and the rubber is really hard or whatever... i put new stripping on last year and it did the same it took a few weeks for them to shut normal
1972 C-10...402/400..flowmaster 40 series 1967 Mustang 347 stroker/C-4 1966 Mustang 289/3-speed 2013 Mustang V6/6speed w/300 ponies I may be 23, but i sure do knows 67-72s are sexy! Its not MPG its smiles per gallon! build started 11/25/08 build thread: http://67-72chevytrucks.com/vboard/s....php?p=2993796 |
Does it ever get cold in Hawaii?
I had the opposite problem.
Stock glue-in rubber left a couple air gaps. I bought the press on (actually had to tap on with hammer) and finally can drive 60mph without whistling and feeling a draft. ![]() |
![]() Join Date: Jan 2002
both of my trucks that have new weatherstipping are the exact same way. It makes it a big pain in the butt to align the doors well. I'm trying to find some nos door weatherstrippin for my 72.
68 Chevy CST/10, 50th Anniversary, 327/th400, 373 posi, buckets 68 GMC Shortbox Stepside, 402/th400, Tilt, Tach, Bucket Seats, 3.08 Positraction 69 Chevy Camaro SS, 383, 4 speed, positraction 70 Chevy El Camino SS396, Triple Black, 454/th400, Tach 70 Chevy Shortbox Stepside 4x4, 350/th350, Tilt, Tach, Cab Lights, Bumper Guards, Tow Hooks 70 Chevy 3/4 Longbox, 350/auto, 70k, SURVIVOR 71 Chevy Blazer, CST, 350/auto 71 GMC Sierra K2500, 454, 4 speed, 4.10 posi, 37s 71 Custom/30, Open Road, 350/th400, tilt 72 Chevy Shortbox Fleetside, 496 Stroker/th400, Tilt, Tach, Bucket Seats, 3.42 Posi 72 GMC Sierra Grande 2500. 427/th400, tilt, a/c, tool and stowage, buckets/console, 3.54 posi |
#15 |
I don't think they will ever soften up. It's a crappy replacement part. Not sure of the manufacturer but you may try metrosoft. In the Camaro world these seem to work the best.
