02-02-2009, 11:28 PM | #1 |
bump stops
i have a 71 chevy.I was wonder what people on here did about bump stops that had air bags on there trucks. Is it somthing that is need in case something goes wrong with the air ride. If so what is the best kind to get and where to get them. pictures from anyone that did this would be great.
Thank you Jon Last edited by centralchevyman; 02-02-2009 at 11:52 PM. |
02-03-2009, 01:38 AM | #2 |
Texas Big Wig
Re: bump stops
Its a good idea to design your suspension with a bump stop or something to keep the suspension from hitting the ground if a bag pops
02-03-2009, 12:58 PM | #3 |
Re: bump stops
The frame or suspension does not hit the ground when it is all the way down. Are ump stops still needed if so what kind should i use.
02-03-2009, 03:46 PM | #4 |
A guy with a truck
Re: bump stops
Do your front tires hit the inner fenders when aired-out? If so, I would set a bump stop just before they touch, that way you do not lose your steering. If you are using upper plates, you can replace one of the mounting bolts with a screw-in style bumpstop from Energy Suspension or the like. Trim or shim as necessary to set it where you like...
-Chris Instagram _elgringoloco_ '70 Short-Wide How to: Ruin a perfectly good C10 ‘70 Blazer ConversionHow To: Ruin a Perfectly Good 4wd '72 Highlander How To: Ruin a Perfectly Good K/5 (SOLD) '72 Blazer 2WD How to: Ruin a perfectly good Blazer (SOLD) '05 Yukon Daily Driven (not so stock) Yukon (SOLD) ‘07 Yukon Denali (daily) Members met list: SCOTI, darkhorse970, 67cheby, 67cheby'sGirl, klmore, porterbuilt, n2billet, Fastrucken, classicchev, Col Clank, GSFMECH, HuggerCST, Spray-Bomb, BACKYARD88, 5150, fine69, fatbass, smbrouss70, 65StreetCruiser, GAc10boy |
02-04-2009, 12:44 AM | #5 |
Happy to be here
Re: bump stops
Take a close look at this pic. Hopefully you can see what was built here. The guys that set up my suspension built a riser to bolt in place of the bump stop. This allows the suspension to rest on the stop and the truck will still roll.
It's a very functional option to have.
Follow me on Facebook and Instagram @N2trux.com Articles- "Jake" the 84 to 74 crewcab "Elwood" the77_Remix 85 GMC Sierra "Scarlett" "Refining Sierra" Last edited by N2TRUX; 02-04-2009 at 12:44 AM. |
02-04-2009, 10:48 PM | #6 |
Re: bump stops
That picture helped out alot. Thank You for picture and help. I was just wanting to see a good way to make them.
02-05-2009, 11:04 PM | #7 |
GM ONLY BABY!!!
Re: bump stops
My Slam Specialties RE7 bags have built in bumpstops. And that is how I roll.
2 wrongs don't make a right, but 3 lefts do. 66 Chevelle Malibu 406ci, 573hp, 10.99@121mph 96 Chevy Silverado Z71 72 GMC 1500 Super Custom LS 6.0/4L65 on airride http://www.cardomain.com/ride/707879...mc-c-k-pick-up |
02-06-2009, 09:50 AM | #8 |
Re: bump stops
I've read that the built in bump-stops on the Slam Specialties aren't designed to support the entire weight of a vehicle.
