Old 02-04-2009, 11:24 AM   #1
turner15
steps for assembling the front end
Can someone outline the steps for assembling the front end of a 71.
Here is where I am at.
Fenders are on
Hood is on
Cowl is on
Grill won't fit
Cowl has a 1/2 in gab on the one side
Hood won't shut tight on one side
gaps are not so good on the hood but are good on the door to fender?
I was told to start over but I'm not sure what order to bolt it down? I know the fenders go on first but do the front sections get tightened now or after the grill? And so on...
turner15 is offline   Reply With Quote
Old 02-04-2009, 12:47 PM   #2
fine69
fine69's Avatar
Re: steps for assembling the front end
There is no perfect science to it. Trial and error on each truck.
Remember, each part has a varience in size. If each part is a little off it can mean a lot as a whole.
Sometimes a die grinder is your friend when it comes to fender fitment.
2008 Chevy HHR 1/2 panel.
1949 Chevy Panel truck(just sittin, waiting)
Board member #6
fine69 is offline   Reply With Quote
Old 02-04-2009, 01:09 PM   #3
Richard Dobson
I'm no expert by any means, but I have left the rad support loose which will allow you to shift everything (fenders, innerfenders) left or right whichever is necessary to get it all adjusted. Good luck, it's good to see everything all taped off in the gaps.
Richard Dobson
Richard Dobson is offline   Reply With Quote
Old 02-04-2009, 01:17 PM   #4
mas09ts
mas09ts's Avatar
Just make sure you have the spacers where you need them.
Mitch
22yrs. Young
1970 GMC Short-Step 350/TH350 Combo. . . . Sold Dec 2011
Current Project 68 Gmc "Second Chance"
Go to my 68 GMC Shorty Rebuild Thread
http://67-72chevytrucks.com/vboard/s...39#post6341739
mas09ts is offline   Reply With Quote
Old 02-04-2009, 01:03 PM   #5
Also, if your cab was removed make sure the cab is squared before you start installing pieces. It's a big mistake alot of us make the first time, even if it is a 1/8 to 1/4 inch cockeyed it'll throw everything off
Aftyer you are sure the cab is square on the frame, loosly attach everything and adjust as necessary with shime and all. As mentioned, it is a trial and error process AND requires lots of patience.
Even if everything came off the same truck, it will need tweaked. It really gets different when parts come from different trucks and aftermarket sources.
Old 02-04-2009, 01:06 PM   #6
67ChevyRedneck
67ChevyRedneck's Avatar
Was everything pre fit before paint? Are any of the parts aftermarket (fenders or hood)?
Jesse James
1967 C10 SWB Stepside: 350/700R4/3.73
1965 Ford Mustang: 289/T5-5spd/3.25 Trac-Loc
1968 Pontiac Firebird: Project Fire Chicken!
2015 Silverado Double Cab 5.3L Z71
2001 Jeep Wrangler Sport 4.0L 5spd
2020 Chevrolet Equinox Premium 2.0L Turbo
2011 Mustang V6 ~ Wife's ride
American Born, Country by the Grace of God
1967 CST Shop Truck Rebuild!
My 1967 C-10 Build Thread
My Vintage Air A/C Install
Project "On a Dime"
Trying my hand at Home Renovation!
1965 Mustang Modifications!
67ChevyRedneck is offline   Reply With Quote
Old 02-04-2009, 01:17 PM   #7
turner15
I really am thankful for the advice. I never thought of squaring the cab! My cab mounts were gone with Canadian rust. Next question is how do you do that? How about a carpenters square against the back of the frame?
Old 02-04-2009, 06:35 PM   #8
I did an cross measurement from the outer top corner of the driver' firewall to the front edge of the passenger frame rail. Then from the passenger side top outer firewall corner to the front of the drivers frame rail. If your measurement is the same, the cab is on square.
BTW I kept my cab mounts (still are in fact) bolts loose until I had things fitted.
Old 02-04-2009, 07:15 PM   #9
mbgmike
Good advice. You won't get it square without doing this.
Another thing alot of people don't do is start off with a truck thats sqaure to begin with. Its not cheap but It really helps to check the frame to see if its correct. I know it cost money but guys have brought trucks in where they did everything to get them correct but the frame was all out of wack before they even started. $800 dollars later (@$98 dollars per hr)on a frame machine and all their aftermarket parts fit good.
You have to check the diagonals . Alot of aftermarket panels can get a bad wrap when the truck wasn't straight to begin with and you have an inexperienced person putting them on. Some aftermarket parts do deserve a bad rap
mbgmike is offline   Reply With Quote
Old 02-04-2009, 07:46 PM   #10
b-rad
b-rad is offline   Reply With Quote
Old 02-04-2009, 07:47 PM   #11
b-rad
hope this helps
Old 02-04-2009, 10:38 PM   #12
LockDoc
The Older Generation
LockDoc's Avatar
Originally Posted by b-rad View Post
hope this helps
That's worth rep points....
LockDoc
Leon
Old 02-04-2009, 07:29 PM   #13
Kayotic
Kayotic's Avatar
Even in today's high tech manufacturing facility's there is still a guy at the end of the line with a rag and a big rubber mallet.
Trial and era - one piece at a time.
Just get the cab exactly where you want it and assemble from there.
Atlanta Craigslist
Hurst Indy Pickup Truck 3-Speed Shifter - 5010016
Kayotic is offline   Reply With Quote
Old 02-04-2009, 07:58 PM   #14
Kayotic
Kayotic's Avatar
The diagram makes it look so easy!!
Atlanta Craigslist
Old 02-04-2009, 11:58 PM   #15
Green Machine
Green Machine's Avatar
Hope you have new rubber cab and rad support mounts. Start with no shims under rear of cab and 1 square shim at the front. Cab has to sit square on frame and line up well with box. I have had to use an extra shim at the driver rear several times to ger the rear window line to line up with the box top edge.
Also measure the rad support side to side and get that centered, or your bumper will not center on the grill. One side or the other of the read support may need a shim to get it level.
Once everything is close, the hood becomes your alignment tool. Be prepared to loosen and re-adjust everthing many times. When you change one area, it will likey have an effect somewhere else.
1968 C10 307 3spd Long Fleet ------ http://67-72chevytrucks.com/vboard/s...d.php?t=201103
1970 C10 305 Super T10 Long Fleet --- http://67-72chevytrucks.com/vboard/s...d.php?t=202285
1971 C20 383 TH350 Dana Posi ----- http://67-72chevytrucks.com/vboard/s...d.php?t=206894
2001 GMC Sierra 1500 C3 6.0
Green Machine is offline   Reply With Quote
Old 02-05-2009, 06:17 AM   #16
b-rad
if any one needs any factory assembly info i have the book
