I am building a 67 short bed using a 72 short bed frame and a 67 cab and front clip, the 67 has a home grown 327 and a turbo 350, the donor frame has a latter model rear end (based on the fact that someone moved one of the shock mounts from the back of the tube to the front) (maybe 73) anyway would a 73 short bed drive shaft work or am I bound for a trip to the drive line shop.
Re: Getting the Shaft
A good parts dealer can match/mis matched a universal u-joint with what you need. They are slightly more expensive about $22 sometimes they need to order it. All you need is correct length shaft.
'69 Chevy Long Fleet & '71 GMC Short Step & Project "ODD BALL" "You can wash a pig, soak it in most expensive perfume. In the end it is still just a pig." ODD BALL build thread http://67-72chevytrucks.com/vboard/s...d.php?t=478629" |
I would think a Bastard joint would solve connecting the two.
About the length; I am not sure. |
