Wide Eyed User
Removing in Cab Gas Tank Supports
Are they pressed in or part of the cab itself? 62 pickup
Thanks for any help!
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ![]() |
Re: Removing in Cab Gas Tank Supports
Mack, just drill out the spotwelds and they will come right out.
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD |
Wide Eyed User
Hmm okay I will take another look, but I didnt see them. Thanks!
you may need to use a flap disk or wire wheel to uncover the spots.
in the '64-'56'-66 they are part of the rear cab mounts and seem to add some rigidity to the back wall of the cab.... My thinking on my is to just cut off the front portion that sticks out for the tank to sit on. not sure about the '60-'63 cabs
1 thing at a time is progress.
I'm confussed. Is this what you are talking about.
Alan
Philippians 2:14-16 |
Wide Eyed User
Was. lol
Wide Eyed User
here are the pics for anyone interested.
13 weld spots per bracket... if you add the four bolts holding it down..lol.. this thing wasn't going anywhere!... lmao.. talk about overkill. ![]() ![]() ![]() ![]() Worth taking out IMO .. look at the rust lurking behind it! Only one oopsy ... 25 partial holes and 1 oopsy..lol
1962 Chevy P/U SB Fleetside 350/350 2.5/5 static drop My Build: http://67-72chevytrucks.com/vboard/s...d.php?t=294723 Final (as final can be ![]() Last edited by DaddyMack; 02-08-2009 at 07:41 PM. |
Are you just going to use a nut and washer on your cab mount bolt? Or is there other plans?
Alan
Resistance is Futile
You just removed your sub-box mounts........
64 CHEVY PICK-UP > http://67-72chevytrucks.com/vboard/s...otrash+re-hash 64 CARRYALL >http://67-72chevytrucks.com/vboard/s...=1964+suburban 66 LB >http://67-72chevytrucks.com/vboard/s...d.php?t=427852 STRENGTH/DETERMINATION/MERCILESS/FOREVER .......posted via stationary device |
Junior Member
Hey Y'all!!
I'm curious about this too...
Just hopin' I live long enough to finish something!!! |
Mack, Looks good. I did the exact same thing in my cab. Including drilling through the back of the cab in one place...
1963' Chev Custom Cab 502, 67' 435hp 3X2 intake, 9" 4:30 Posi 1961 Impala SS 348/350 4-speed 3:70 Posi 1961 Bel-Air Bubble Top 283 Turboglide soon to have a 348 3X2 4-speed 1950 17' Fairliner twin cockpit barrel stern 312 Y block 1X1 intake Borg Warner 1:1 gear 1957 Fleetform 14' twin cockpit barrel stern 1969 BP-125 Merc 1949 Transitier 3-wheel forklift Crosley 4-Banger 98' FXD 2002 2500HD Last edited by 502tripower; 02-09-2009 at 11:22 AM. |
Hey, what did you use for your cab mounts?
Damn your fast Joe.....
#15 | ||
Wide Eyed User
Hehe! Nothing that cant be covered ![]() LMAO!!! I discussed this exact thing with my kid..lol... BUT the rust I could see, plus, I am not sure exactly what seats, etc. are going in... Thinking.. 98 silverado... I wanted the room BUT here is a question.... or thoughts....sand surface rust? then just spray paint using paint with a rust inhibitor? then coat entire bottom portion of cab with rhino liner before putting in sound deadener? or just use the rhino in the footwells? or ???? trying to figure out best way to treat it...most if it will be covered with carpeting...
#16 |
I would do all of that. Sand, wirebrush, whatever you prefer. Im not sure what rhino liner can be sprayed on, but maybe self-etching primer. Rhino the whole floor .......fill in your threaded holes first.
Good to see you back on here with some updates.
#17 | |||
![]() ![]() Quote:
here is a link to one site that sells it http://www.tptools.com/p/2600,233_U-...Liner-Kit.html
#18 |
Junior Member
If you're going to be the Sheriff, you have to be quick on the draw!!
#19 |
Shloooooong bed member #2
David, Daughters 66 truck: http://67-72chevytrucks.com/vboard/s...d.php?t=484601 Learning to drive a 3 on the tree: http://www.youtube.com/watch?v=CcCMvRgBo1Q |
#20 |
