lowering my 78
I have a 78 blazer 2wd. It has 2 inch drop spindles. Everything else in stock. I want to go a little lower. Is the best way to use 2 inch drop springs and shackle and hangers out back?
here is how it looks now ![]() |
6.0 powered square
Re: lowering my 78
the spring hangers are a hassle to install, also the shackles you will have to modify the filler hose, a flip kit would be the easiest and cheapest
http://store.summitracing.com/partde...5&autoview=sku
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 Last edited by flamingbig10; 02-08-2009 at 03:44 AM. |
Low & Fast!
Re: lowering my 78
Or take a leaf or two out, One long one and the over load.
Re: lowering my 78
are hangers and shackles the same for a pickup and a K5 blazer of the same year?
Re: lowering my 78
No. The shackles will bolt up but contact the gas tank filler neck on the passenger side. The hangers bolt holes match but you will have to cut holes in the bed floor as they are to tall. like flaming and tvblazer suggested, either a flip kit or remove leaves.
It followed me home?
Re: lowering my 78
Depending on how much drop you want I would start by taking a leaf or two out. I installed a flip and ended up getting about 8" of drop
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
#7 | |
I know the pieces fit
Re: lowering my 78
