Old 02-08-2009, 09:31 PM   #1
bigblock73
yeller
bigblock73's Avatar
school me on 67-72 cabs please!
I am trying to help out a friend, and would like some help from all of the 67-72 experts on here. Are 67-72 pickup cabs identical and completely interchangable for all years...in terms of sheet metal and such? If not, what exactly are all the differences between the 67-72 years? Also, what about the gas tanks, same size and dimensions? I am not concerned with electrical, gauges, columns and such...just the sheetmetal (inside and out) along with gas tank size and placement. Thanks in advance, I appreciate all your help!
bigblock73 is offline   Reply With Quote
Old 02-08-2009, 09:52 PM   #2
OARNGESI
OARNGESI's Avatar
Re: school me on 67-72 cabs please!
I think a bare cab with nothing the only change is the back windaw but thats completely bare
70 SWB STEPSIDE
70 BLAZER
09 challenger
OARNGESI is offline   Reply With Quote
Old 02-08-2009, 09:55 PM   #3
John Fabris
TOTY 2006
John Fabris's Avatar
67-68 cabs have different ebrake and throttle set up then 69-72. 67 cab could have small rear window. 72 cab has door vent (black plastic grille below driver side door latch). Minor dash changes from 67 to 68-72. (67 dash has different ignition switch area and different lighter area). Overall, not a big deal using different year cabs. Biggest issue is the vin plate and the laws about changing that.
John Fabris
67 C10 SWB
John Fabris is offline   Reply With Quote
Old 02-08-2009, 09:57 PM   #4
Tx Firefighter
Watch out for your cornhole !
Tx Firefighter's Avatar
There are some minor differences. The location of the fuebox changed over the years for one thing.
Later cabs had a pressure relief vent in the door jamb too.
Absolutely nothing that can't be overcome though
I'm on the Instagram- @Gearhead_Kevin
Tx Firefighter is offline   Reply With Quote
Old 02-08-2009, 10:21 PM   #5
DMARCUM123
1971 cab has a raise in the panel where inside mirro bolts, and the 72 mirrro was on the windsheild
DMARCUM123 is offline   Reply With Quote
Old 02-08-2009, 10:29 PM   #6
67_C-30
I have a radical idea!
67_C-30's Avatar
Adding to what others have said, '67 has a 1 year only slider type ashtray. '68 - '70 has a ball-bearing roller type ashtray. '71 - '72 has a slider type ashtray. Starting in '69, a rear cargo light was optional. Also '67 - '68 had both the headlight and wiper switch on the left side of the cluster and a choke knob (or choke knob delete plate) on the right. The '69 - '72 had the headlight switch on the left and the wiper switch on the right.
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 02-08-2009, 10:29 PM   #7
msgross
msgross's Avatar
I know that 68's had these "squirly" patterns in the floor (not sure why) and the rear angle brackets under the gas tank (more support?)
Some also had removable humps over the tranny. This didn't matter for years but all 4wd's and bigblocks with floor shift had them...
The Garage:
1968 K-10 SWB - "Project Money Pit"
1996 Z-71 - "huntin rig"
1969 C-10 LWB (SOLD) "Project flip that truck or else"
1993 Passport, F@rd 1-ton (SOLD)"Project Cousin Eddie"
My Garage Build "The 1,000 footer"
msgross is offline   Reply With Quote
Old 02-08-2009, 10:55 PM   #8
msgross
msgross's Avatar
This is what happens when you ask for "details" on this board!!!!
Not only was the gas pedal different but the floor in 67-70? had a raised pad and two holes for the pedal to mount to...
The Garage:
Old 02-08-2009, 11:04 PM   #9
68_Bowtie
68_Bowtie's Avatar
All of the above posts just about cover the differences as far as I've found. Just changed my 68 cab over to a 72 last fall and am still in the re-building stages. I'm gonna use the fuel tank out of my 68 and I haven't bought the grommet for the neck yet, I'm pretty sure they are different.
68' SWB 355 CID since 1987
89' S15 4WD 4.3
08' VTX 1300R
08' Chevrolet HHR (Wife's ride)
"That man right there is the best sprint car driver in the whole ---damned country!" 1974- Indianapolis- AJ Foyt pointing out Jan Opperman in the garage.
68_Bowtie is offline   Reply With Quote
Old 02-08-2009, 11:50 PM   #10
bigblock73
yeller
bigblock73's Avatar
Wow, you guys are great!! Thanks for all the help, feel free to add more as you think of it. Hope you all had a great weekend.
Old 02-09-2009, 10:56 AM   #11
Shane
Shane's Avatar
I'm thinking the section of the dash where the ignition switch and the same area where the cig lighter are located are different on a 67 cab versus the other years. They aren't as "deep" of a recess.
Shane is offline   Reply With Quote
