Old 02-09-2009, 11:03 PM   #1
SeventyOne
Backspacing for a 4x4?
I was looking around and using the search but couldn't come up with an answer.
What is the maximum backspacing for a wheel on a '71 4x4?
I am going to be lifting my Blazer and want to run 37's and 17x8-10 rims. Some of the wheels I like have 4.5" or even 5" of backspacing (seems like most 17s do) and I was wondering if anyone here had experience with wheels like this.
Thanks in advance.
SeventyOne is offline   Reply With Quote
Old 02-10-2009, 06:46 AM   #2
vtblazer
vtblazer's Avatar
Re: Backspacing for a 4x4?
Not positive about the 'maximum' but the norm is 4"s.
I've read here somewhere that the guys running the newer style chevy truck wheels have to run spacers.
I have H2's on my D60 without spacers, their a 17" wheel, what axle are you running?
vtblazer is offline   Reply With Quote
Old 02-10-2009, 04:12 PM   #3
SeventyOne
It's the stock Dana 44 in the truck. I suppose I could get the wheels and if I have fitment issues I can run some spacers.
Old 02-10-2009, 06:15 PM   #4
Burt4x4
Burt4x4's Avatar
The maximum is when it hits! hehehe just messin..probly close to 4.5" but I have never tried to max it out so I could easily be wrong.
On that D44 I would stick to 3.5-3.75 range 4" max....test fitting is your best answer
1972 K5 MPFI454/Sm465/Np205/D60/14FFd/Re-Centerd H1s w/Swamper Iroks
Burt4x4 is offline   Reply With Quote
Old 02-10-2009, 07:00 PM   #5
vtblazer
vtblazer's Avatar
Personnally I'd feel safer without spacers if I were driving it on the roads.
A wheel with 4"s of back spacing is close with a 12.5" wide tire on a 10" wheel, from there it all depends on what your runnin' for rubber.
Although a 17" wheel could possibley give you a little more room with the tie rod end.
Old 02-10-2009, 07:46 PM   #6
SeventyOne
I will have to keep my eyes open for 17s with less backspacing. Or just go with 15's in the backspacing range I need - but there is such less variety and style in that size wheel.
This truck will only be drivin on the road.
Old 02-10-2009, 11:00 PM   #7
Mike C
Mike C's Avatar
I have my stock Dana 44 in the front with 8 lug hubs from an '86 Suburban and I have the Sub semi-float 14 in the rear. I am running 16.5 x 10 Centerlines with 4.5" b/s. No problems. Rear is wider than stock, 8 lug hubs in the front maybe slightly?
44 Willys MB
52 M38A1
64 Corvette Coupe
68 Camaro 'vert LT1 & TH700
69 Z/28 355 12.6's @110
72 Jimmy 4WD 4spd 4" & 35's
02 GMC 2500HD 4x4 Duramax
