Old 02-10-2009, 04:53 PM   #1
cstm68
cstm68's Avatar
rear disc calipers?
who here is using the cadilac siville rear e-brake calipers? what year cady do they come off? also what e-brake cables do i need? can i use my stock cables?
68 swb fleet bagged on 20's 327 with 4 speed http://67-72chevytrucks.com/vboard/s...d.php?t=223308
2014 Chevy 2500hd duramax CCLB
cstm68 is offline   Reply With Quote
Old 02-10-2009, 05:01 PM   #2
cstm68
cstm68's Avatar
Re: rear disc calipers?
ooops i didnt mean to post this in the projects and builds section. i ment to post it on the regular message board. could a mod please move this?
Old 02-11-2009, 02:42 AM   #3
Spray-Bomb
Texas Big Wig
Spray-Bomb's Avatar
Its not seville only, its the big cars with 5x5 pattern & have rear discs
I think mine are from a 76 or something, I dont really remember
I havent gotten them on yet, but I dont think the stock E-brake cable will work, you need to adapt from the stock one on the truck to the ones on the disc calipers
Maybe someone else has more input
Here is a thread with the years & models that had 5x5
http://67-72chevytrucks.com/vboard/s...d.php?t=234769
Just not low enough...
Sinister
Killer
Spray-Bomb is offline   Reply With Quote
Old 02-11-2009, 11:16 PM   #4
cstm68
cstm68's Avatar
what 6 on 5.5 rotors will work with these calipers?
Old 02-12-2009, 10:30 AM   #5
Shane
Shane's Avatar
Cadillac Seville '77-'79 model years use 5 x 5" rotors ... I am using this model caliper as well. You will need to do some machine work on the axle flanges as this is not a bolt-on mod.
You will also need to make / fab brackets to mount the caliper as the caddy mounts will not work.
Shane is offline   Reply With Quote
Old 02-12-2009, 11:58 PM   #6
cstm68
cstm68's Avatar
oops i ment what 6 lug 6on 5.5 rotors will work?
Old 02-13-2009, 06:44 PM   #7
Sir Fisher
Sir Fisher's Avatar
on my rear axle i'm using 76-78 eldorado rear calipers and 92 Astro Van all wheel drive front rotors 6 on 5.5; here a pic.
1970 Chevy K20 Custom Camper
1996 Chevy Impala SS
2008 Chevy Avalanche LT3
2003 Honda Accord EX
2001 Hewes Redfisher 16 Fighting Lady Yellow
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=324118
Sir Fisher is offline   Reply With Quote
Old 02-14-2009, 04:46 PM   #8
70clone
70clone's Avatar
so astro vans awd are 6 lugs if so that is sweet
70clone is offline   Reply With Quote
Old 02-19-2009, 02:12 PM   #9
Sir Fisher
Sir Fisher's Avatar
i'm so sorry guys; i gave wrong information... i double checked with my informant and for 6 lugs it's a 92 1/2 ton p/u 4X4... the astro vans are 5 lugs.
Old 02-19-2009, 10:33 PM   #10
cstm68
cstm68's Avatar
are theos off the front? and do they fit over the hub?
Old 02-20-2009, 12:50 AM   #11
Sir Fisher
Sir Fisher's Avatar
they are off the front of a 92 K1500. for my rear 12 bolt and yes, it fits over the hub.
Old 02-19-2009, 12:24 AM   #12
cstm68
cstm68's Avatar
so i tried and astro rotor but it wouldnt fit over the hub,
what si the best way to convert to rear disc with and e brake?
Old 02-19-2009, 12:46 AM   #13
powerbench
powerbench's Avatar
hey sir fisher, how do the calipers fit in a 15 inch wheel ..any clearance problems...i just bought a set of backing plates , on the off chance it will work on my 12 bolt.
powerbench is offline   Reply With Quote
Old 02-19-2009, 07:27 AM   #14
Chevy4Life
Chevy4Life's Avatar
I was going to ask if the astro rotors fit over the hubs. He probably turned them down if you tried them and they didn't fit. I used 88 4x4 front rotors and had to turn the hubs down. Most guys have them done at a machine shop. I had a bare frame, so I used a BIG drill on the yoke nut and a grinder on the hub.
I wonder if the astro and 4x4 rotors are the same. It looks like they have the bigger lug holes like the 4x4, because GM went to a bigger stud and the stud is pressed into them.
Jay
Chevy4Life is offline   Reply With Quote
Old 02-19-2009, 07:30 AM   #15
Chevy4Life
Chevy4Life's Avatar
I'm on 15" rollers right now and they fit fine. They aren't stockers just cheap chrome wheels.
Jay
Old 02-19-2009, 11:30 AM   #16
Sir Fisher
Sir Fisher's Avatar
they should work fine... but don't quote me... i tried it with a 16" wheel and it fits fine with room to spare.
