Old 02-10-2009, 07:45 PM   #1
onesmokinduramax
HELP Please 85 GMC body fit on 74 chevy frame
Hi im pretty sure this would fit but i just found a nice 85 GMC cab,dog house and bed for 200 bucks... this will bolit right up to me 74 chevy4x4 frame right with out any mods? just want make sure befor i make the drive to get this body.. Is there any thing to look for on the cab to watch out for? This is my first time doing a swap with a body.
Also whats the difference between these years on the wirings meaning how do i find out witch wire is what?
thanks
Mark
04 Chevy Duramax LLY crewcab 4X4
Built ATS Allison Upgrades making around 500HP!
75 chevy 3/4 ton 4x4 its got a built 350 with dana 44 and a lift.
onesmokinduramax is offline   Reply With Quote
Old 02-11-2009, 05:41 AM   #2
wildlandfirefighter
wildlandfirefighter's Avatar
Re: HELP Please 85 GMC body fit on 74 chevy frame
Right now i have a 84 body on a 73 2wd frame without any problems at all. so i would say you would have no problems, but maybe there is something different with the 4x4s. And look for rust cab corners, rockers, floors, and on my cab i have rust on my front window seal area in which i dont know how i an going to fix.
wildlandfirefighter is offline   Reply With Quote
Old 02-11-2009, 11:51 AM   #3
onesmokinduramax
Ok i thought it would. Only place the guy said there was rust on the cab was a few small holes in the rocker.. The bed has a big dent in it by the tail light but i dont think that is a big deal.. The cab inside not bad shape its alot better then what i have! but it would need a new seat
Heres a few pic
Old 01-18-2017, 11:57 PM   #4
buck1983
I'm starting this very swap. 84 body over to a 73 frame. what did you do about the bumper and core support? I see cut the 73 frame, but no other details...
buck1983 is offline   Reply With Quote
Old 04-25-2018, 02:44 PM   #5
Manzano75
Manzano75's Avatar
Did you replace the mounts? Please tell me which ones did you use? the 70's or 80's cab mounts.
Manzano75 is offline   Reply With Quote
Old 02-11-2009, 11:58 AM   #6
old Rusty C10
Robert Olson Transport
old Rusty C10's Avatar
the only issue is you have to use the rubber body moounts that work with the frame IIRC.I did this with a 76 frame and an 81 cab. you may want to shoot a PM to CaptKaos as he is our resident expert there are other things if you are going to use the nose of a 73-80 on and 81-87 cab tho do you need that info?
Bob
1951 International running on a squarebody chassis
"If a man's worth is judged by the people he associates himself with, then i am the richest man in the world knowing some of the fine people of this board"
http://67-72chevytrucks.com/vboard/a...t.php?f=25&a=9 (you can review the site rules here!)
PM Me for your vehicle/parts hauling needs in the North East US or see my Facebook page Robert Olson Transport
Live each day to the fullest.. you never know when fate is going to pull the rug out from under you...
I hate cancer!!
old Rusty C10 is offline   Reply With Quote
Old 02-12-2009, 11:52 PM   #7
wicked_sky_gazer
Living Legend
wicked_sky_gazer's Avatar
Hey I'm doin the same 81truck on a 76 frame use 76 body mounts and there is no isues?
'81 c10 sw 355cid roller motor 350turbo with stage two shift kit, poor rear end gearing, not sure peg speed... speedo is mia..
project is temporarily on pause again... Thankyou wonderfull economy.. check it out
Im not to worried i have an uncaning ability to save myself from some weeeiiirrd crap
East Ok meet East Ok date
Tony
wicked_sky_gazer is offline   Reply With Quote
Old 02-13-2009, 10:23 PM   #8
onesmokinduramax
Well i picked up the truck to day. I got there and he let the frame go with it. Its a 2 wheel drive frame so i can not use it. But got a question with this being a 2wd will i have to replace the hump in the cab to fit my 4x4 frame? I will be puting a 3 inch body lift on it..
By the way the cab and dog house is in great shape lot better then the pic shows! could not pass the deal up that he give me.
Old 02-14-2009, 01:03 AM   #9
ChaseDale3and8
ChaseDale3and8's Avatar
Since the high hump floor is just for clearance of the transfer case and you plan to use a 3" body lift I see no problems since 3" should give you plenty of clearance. You'll just have to cut the hole for your transfer case shift lever.
If you decide to replace the rubber mounts in the frame be sure to buy them for the year of frame, not the body. 81-87s are different than 73-80s. I'd suggest installing polyurethane ones. They are much better than the stock rubber ones and will last a lot longer. Good luck and be sure to post up pictures! ...Joe
I'm not speedin'! I'm qualifyin'!
ChaseDale3and8 is offline   Reply With Quote
Old 02-14-2009, 04:34 PM   #10
thinair
thinair
thinair's Avatar
good answer.
thinair is offline   Reply With Quote
Old 02-11-2009, 02:33 PM   #11
dooce
I thought you used cab mounts for the year of cab? I may be wrong, its been a while. I know they aren't the same though!
1976 Chevy 1/2T 2wd SWB
327/Saginaw 4spd 3.73:1
LQ4 6.0/T56 Build thread http://67-72chevytrucks.com/vboard/s...d.php?t=772071
LFSalleeII@gmail.com
dooce is offline   Reply With Quote
Old 02-11-2009, 08:36 PM   #12
wildlandfirefighter
i used mounts for the frame not the cab, and i had no problems.
Old 02-11-2009, 10:21 PM   #13
Rollinsqrbdy
Rollinsqrbdy's Avatar
I took a 86 4x4 body and put it on a 77 2wd frame and used the body mounts of the 77.
Its Kool to be a square
2013 Chevy Silverado Z71 w/ 7" lift and 35" Nitto's
1985 C-10 ......My dream truck (under construction)
1984 k 10 Silverado...6" lift with 38.5 super swampers
New Mexico Member
--- Member of the Square Body Club---
Rollinsqrbdy is offline   Reply With Quote
Old 02-12-2009, 11:06 PM   #14
73chevyman
73chevyman's Avatar
i know that 4 wheel drives have a higher center hump. theres a high hump and a short hump and most of the high humps been on 4X4's
http://67-72chevytrucks.com/vboard/group.php?groupid=37
73 C10 Fleetside
If it ain't a Chevy it's foreign
http://hotridesmag.com/
73chevyman is offline   Reply With Quote
Old 02-19-2009, 03:55 PM   #15
Captkaos
www.73-87chevytrucks.com
Captkaos's Avatar
Sorry I have been away for a shot time.
Everything posted is correct.
Cab will work
You MUST use at least a 1" Body lift to clear the trans/transfer
You MUST use body bushings specific to the Frame not the body. All 73-87 body pans are identical, it is the frame mounts that changed.
Chris Lucas
1973 Chevy C-10
1978 GMC Jimmy (2WD) - SOLD
1987 R10 twin turbo LS
1991 R3500 SRW CrewCab
Captkaos Customs
Old 02-19-2009, 04:03 PM   #16
wicked_sky_gazer
Living Legend
Cab will work
thanks
Tony
Old 03-09-2009, 10:09 PM   #17
onesmokinduramax
Im doing the swap now i got the old body off and the new cab just siting on the frame... I have looked on ebay and all over the web and cant find a body mount kit for my frame. can you tell me some where to get them? the frame is in the year 74-79. Also the old body did not have any body mount bushing at all just had a 3 in body lift in place. Is there any thing that i would need to buy with the body mount I have been working on it and just ran in to this issue.
Thanks Mark
Old 06-21-2016, 02:18 PM   #18
1978-Chevy-Step-Side
Originally Posted by wicked_sky_gazer View Post
thanks
So as long as you use the bushings specific to the frame the body's should transfer
1978-Chevy-Step-Side is offline   Reply With Quote
Old 06-21-2016, 02:40 PM   #19
bbbc10
Diggin The SquareLife
talk about a thread being brought back to life!
bbbc10 is offline   Reply With Quote
Old 06-21-2016, 02:55 PM   #20
chevhot
i just did a frame off on my 1980 GMC used mounts for year of frame also the VIN tag is in a diff location and the wipe switch you need to cut a new hole for that. and wiper arms from the 74 and also the the light switch need to relocate that's all if you are using the 74 dash and interior and nose from the 74
chevhot is offline   Reply With Quote
Old 03-09-2009, 10:14 PM   #21
wicked_sky_gazer
Living Legend
Summit sells them, brand name is energy suspension I believe local parts houses Cary to, around here anyways
Tony
Old 03-09-2009, 10:26 PM   #22
Storm Chaser
Storm Chaser's Avatar
LMC carries the body mounts also.
One question for everyone doing the 73-81 frame with a 82-87 cab (or vice versa)... what are you all doing at the front bumper? I know the frame changed there for the different bumper and corresponding mounts.
1988 R2500 Crew Cab
Immediate plans- get it running!
Future plans-
Rear disc swap & Hydroboost
Dually conversion with shackle flip-n-switch
4x4 conversion with 52" springs
Maybe some new body panels
Who needs a car when they make crew cab trucks?
Storm Chaser is offline   Reply With Quote
Old 03-09-2009, 10:36 PM   #23
wicked_sky_gazer
Living Legend
Mine will be custom.... But the bumper I'm using is off of a completely different vehicle also so I don't think that's of help to you
Tony
Old 03-09-2009, 11:06 PM   #24
Captkaos
Captkaos's Avatar
for 73-80 frames with 81-87 frontends you have to cut the frame ends
Chris Lucas
1973 Chevy C-10
Captkaos Customs
Old 01-19-2017, 10:35 AM   #25
KrazyRay
KrazyRay's Avatar
Use 73 core support bushings and your 84 core support will work. Cut the horn off the frame and use the 84 bumper brackets.
KrazyRay is offline   Reply With Quote
