02-11-2009, 10:35 AM | #1 |
Need help with my new 68 C10...
I want to lift my front end because it sits too low for my taste...it looks like the previouse owner cut the springs to lower it...what year trucks can I get used springs from that will work on my truck? I'm looking for a range of years. Also, I've never lifted a truck and a friend of mine said all I have to do it put "spacers" and that will lift it..? Are spacers a good idea? Safe? Here's my truck...
02-11-2009, 11:11 AM | #2 |
Re: Need help with my new 68 C10...
67-72 springs will fit...check the parts board here on the site...thought I saw a pair for sale.
Cut springs equal rough ride usually. You could order new springs for $100 a pair from ECE to cure the problem. PS...never used spacers...they just don't seem like a good idea to me.
Kelly '05 GMC Sierra SLE Z71 Bone stock except for new bed rail caps. Last edited by Gray Ghost; 02-11-2009 at 11:11 AM. |
02-11-2009, 11:14 AM | #3 |
Thanx! What about the install? Is that a hard job to do? I have limited experiance with these trucks. Will I need special tools for this job?
02-11-2009, 12:31 PM | #4 |
Project Junkie! Fishing Poor!!
Not a bad job to do with limmited tools. Floor jack, jack stands, 15/16" socket, needle nose plyers, and a 3 pound hammer should do the job. Sometimes if the spindle is being stubborn, you may need a pickle fork also.
1) Jack the front of the truck up by the large crossmember under the motor. 2) Place jack stands under the frame rails just forward of the front of the front cab mounts and let the jack back down. (Making sure that the tires remain off the ground) 3) Remove the front tires and wheels. 4) Place floor jack under the lower "A" arm and jack it up untill it is about 1/8" away from touching it. 5) Remove the cotter pin that is keeping the castle nut from backing off on the lower ball joints. 6) Back the castle nut off about 1/4". 7) Using the 3 pound hammer, smack the side of the spindle where the lower ball joint is. (This may take a couple of good hard hits) 8) Once the spindle pops loose of the lower ball joint then you jack the floor jack up to slightly lift the lower "A" arm up to relieve the spring tention from the ball joint and castle nut. 9) Remove the castle nut. 10) Lower the jack slowly to alow the "A" arm to open up. 11) Remove the old spring. 12) Replace with the new one making sure that you place it correctly into the pocket and jack the lower "A" arm back up. (This will take some quardination or extra hands. You need to make sure the spring is placed correctly, and the spindle lines up on the ball joint all at the same time. 13) Once the ball joint enters the spindle enough to start the castle nut, spin the castle nut on. 14) Then you can jack the "A" arm up untill it tries to lift the truck. (Then stop) 15) Tighten the castle nut to seat the ball joint and line it up to place the cotter pin back in it. 16) Replace tires and wheels and let the truck back down. Done deal!! Hope this helps. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys Last edited by Classic Heartbeat; 02-11-2009 at 10:36 PM. |
02-11-2009, 06:38 PM | #5 | |
I have a radical idea!
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435 ‘72 C-10 SWB , 350 4bbl, TH350 '69 C-10 SWB , 250 L6, 3 OTT '69 GMC C3500, dump truck, 351 V6, NP435 '84 M1009 CUCV Military Blazer 67 C-30 Turbodiesel build thread http://67-72chevytrucks.com/vboard/s...d.php?t=254096 My trucks http://s226.photobucket.com/albums/d...ediafilter=all Member of the 1-Ton Club! |
02-11-2009, 06:54 PM | #6 |
resident oilfield trash
dont use spacers
02-11-2009, 04:40 PM | #7 |
Restoration Virgin!
nice write up Wes!!!....rep points for your time!!!
Geoff with a G 1968 Chevy C10 SWB The Mistress 1972 Custom Deluxe C20 Suburban A Suburban Named Isabella 1966 Ford Mustang Mama's High School Graduation Present |
02-11-2009, 05:10 PM | #8 |
Thanks gcburdic. I try to help when I can. WES
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
02-11-2009, 08:22 PM | #9 |
Classic Heartbeat...ur amazing thanx for the detailed info!!! Everyone else, I appreciate the input! I start looking for springs tomorrow!!! I'll post pics as soon as I'm done. Again you all are awesome!
02-11-2009, 09:36 PM | #10 |
what knocking sound?
It's not a bad idea to run a chain through the A arm and spring...especially for a first timer. Have fun!
1968 C-10 1953 belair two-door post 1955 chevy 3600 big window 1950 studebaker starlite coupe 1968 Impala SS |
02-11-2009, 10:39 PM | #11 |
Thanks guys, I hope it helps everyone out. 67_C-30, I bolded #4... WES
