65 short on a 92 short frame
I bought a 65 for my son a few years back. With the donation of a 92 short wide from one of my sons' friends, we are going to attempt placing the 65 on the 92 frame. Does anyone have knowledge of this swap and what i am getting in to? We have pulled body off of the 65 frame and the body is now sitting on the 92 frame. We have yet to attempt the attaching, yet. Thank for any info...
choctawchevyclassics ![]() Last edited by choctawchevyclassics; 02-12-2009 at 05:56 PM. |
1961 crewcab
Re: 65 short on a 92 short frame
^ so is that it on the 92 frame now?
All I would say is retrieve the cab mounts from the old frame, bolt them back to the cab, and then weld them to your new frame. attach/modify steering,clutch,brakes, and the frame horns for the bumper brackets, and you are ready to go. |
I tried down loading the picture of it on the 92 frame, but I guess it was too big and would not take. The picture is still the 65 frame.
choctawchevyclassics ![]() |
1962 C-10
My brother in law did the same thing. He did similar what Jon says to do. You can resize the pictures in 'Paint' and try uploading them again.
Joseph Chavez ![]() "See the USA in a Chevrolet!!" ......................_____ .........________//__{\_____ ,,,,,,,/__(O)___//___/__(O)_/ 1962 C10 Shortbed Fleetside 327/th350 GV overdrive 1974 C10 Longbed Fleetside 350/th350 "The Trash Truck" 1999 Chevy 2500 OBS, Longbed 5.7/4L80E 4x4 2015 GMC Sierra SLE 1500 4x4 |
Hollister, CA.
![]() Join Date: Sep 2006
Yes.....do it NOW...please !
Sounds interesting....should be cool !
John What the Heck is that ?? CURRENT BUILDS: 62 BurbMaster ![]() Other Builds: My '63 C-10,LWB,CC,BBW '06 HD StrAight Axle Swap Father/Son '67 C-20, LQ9,4L80,Bagged,8-Lugger !!Good Friend Richard's Build AMERICAN CUSTOMS & CLASSICS (831) 630-1965 www.ACCHOLLISTER.com ACC on FACEBOOK "Rest in Peace, Mom & Dad ... I will see you again someday!" |
TexasBowhunter
I did basically what Jon said, but I didnt weld the body mounts.
I drilled the rivet holes and used Grade 8, 7/16" hardware. You will have to measure the frame width to make sure they are the same.
Build in progress for son's first truck. |
![]() ![]() Join Date: Jul 2002
I'll be curious to see how she all works out.
1961 crewcab
I was curious about welding the mounts to the frame... probably better to rivet, or bolt them on... ?
60-66 Nut
The frame on the '92 is considerbly wider than the '65 frame, so just swapping the cab mounts is probably not a simple solution. I would suggest doing some detailed measuring of all your necessary mounts before getting too carried away. I'm not saying it isn't possible, but it may be a bit of work. Also if it is anything like putting a '60-'66 body on a '73-'87 frame, you'll end up with a 3 inch or so body lift when you're done.
towards the bottom there is an image resizer(if you are running windows)
it is very easy to use, after it is installed, just right click picture and resize pic, i use the small setting http://www.microsoft.com/windowsxp/d...powertoys.mspx
Just here to tinker
![]() Join Date: Jun 2008
More pics! Excited to see how this turns out!
![]() And WELCOME ABOARD!!!
78 C10 SWB Diesel #1 (wrecked)http://67-72chevytrucks.com/vboard/s...1978+silverado 78 C10 SWB Diesel #2 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=650751 60 GMC Suburban (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=445526 60 GMC 1000 (sold)http://67-72chevytrucks.com/vboard/s...d.php?t=298235 67 GMC 1500 (sold) http://67-72chevytrucks.com/vboard/s...d.php?t=803695 86 Suburban(summer unit) http://67-72chevytrucks.com/vboard/s...d.php?t=810697 88 Suburban 4x4(winter unit)https://67-72chevytrucks.com/vboard/...25#post8900725 Last edited by Corts60; 02-14-2009 at 12:07 PM. |
"MORE PICS !!! MORE PICS!!!
