Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 02-12-2009, 04:20 PM   #1
americanmusc1e
americanmusc1e's Avatar
Need some advice
I have a '70 long fleet with a brand new (3000 miles) 350 (.060 over) it has home-ported vortec heads, a HE260 cam, 1.6 stamped roller rockers, headers, a weiand stealth intake and a 600 vacumn secondary..... the motor has dished hyperecutec pistons, stock rods, four bolt mains, 9:1 compression and a cast crank......... the truck has a th-350 and 3.08 open diff which i am replacing with a 700-r4 and a 3.73 posi........................... I want this thing to eat a stock '09 challenger (13.2 seconds) for breakfast...... can i do this on my new stock short block?........... what mods are recomended.....my idea is a weiand 142 huffer and AFR 195 heads and a blower cam........I am on a budjet and do what I can when I have the money.......... this is my daily driver...........a HT502 big block would be nice but thats $5600
thanks in advance
americanmusc1e is offline   Reply With Quote
Old 02-12-2009, 04:57 PM   #2
djracer
djracer's Avatar
Re: Need some advice
You can probably get there with a huffer or some spray with the motor like it is. Just be real careful on your tune up with those hyper pistons.
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 02-19-2009, 06:27 PM   #3
americanmusc1e
anybody know how much horsepower a stock cast 350 crank can take if its not going to be revved past 5500????????
Old 02-20-2009, 12:53 AM   #4
nxtruck
nxtruck's Avatar
The crank will take a LOT more than the hyper-pistons you have. Those pistons don't hold up well to any kind of detonation. It's not so much the power levels that will kill it as it is the detonation that could happen trying to achieve those power levels. As Kevin said, watch your tuneup with either power-adder and it will live.
Chris
1966 Chevy C10 LWB, 434 sbc, TH350, 12-bolt, factory suspension, pump gas
7.02 @ 95.8, 1.45 60'
1965 Chevy C10 LWB, 355 sbc, TH350, daily driver
nxtruck is offline   Reply With Quote
Old 02-20-2009, 01:17 AM   #5
LuckyHenriksen
LuckyHenriksen's Avatar
I think that Weiand huffer and some nice heads would put you there. But as stated, the pistons would be the weak link
1968 Yenko Chevy LWB
6.0L/TH400
3/4 Drop
Senior Project
Build Thread Here
LuckyHenriksen is offline   Reply With Quote
Old 02-20-2009, 11:45 AM   #6
scatesracing
Machinist
scatesracing's Avatar
I have hyperecutec pistons in mine......... I spray it with a 200 shot.. and Its still in alive.. I know there is a little luck involved but I always keep it fat ....... And like everyone else has already said dont let it ping.. The last time out I was crossing the line at 7300.... It also has a cast crank. Its a street truck it dosnt get raced every weekend. I dont know that I would trust it to that but I dont hesitate to run the hell out of it. One more little note I built it before my daughter was born...... shes nine now.
scatesracing is offline   Reply With Quote
Old 02-20-2009, 11:56 AM   #7
djracer
djracer's Avatar
be careful too fat will lift the ring land off the pistons. Fuel gets under the top ring land then fires and folds it right up. Its a big misconception that fat is good on a Nitrous tune up. Fat kills more stuff than lean most of the time.
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
Old 02-20-2009, 12:44 PM   #8
Marv D
Registered Truck Offender
Marv D's Avatar
Here's what can happen NORMALLY ASPIRATED with Hypereutectic pistons, cast GM crank and just under 580HP at nearly 6800rpm.
WELL beyond thge reliability of any 'stock' component (block, crank or hyper pistons)
RPM's are much more devistating on the bottom end than brute HP.
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Last edited by Marv D; 02-20-2009 at 12:46 PM. Reason: I'll get this link right YET!!!
Marv D is offline   Reply With Quote
Old 02-20-2009, 07:51 PM   #9
scatesracing
Machinist
I never said it was smart......... And maybe fat was the wrong choice of words. maybe make sure it dosnt lean out. better choice
