Bretzke Racing Inc.
I'm debating whether or not use dropped lower control arms or dropped spindles...problem is, i have 15" rims...so i think dropped spindles are out of the question...has anyone experienced any problems with lowered control arms with 15" wheels? im looking to get about 3" of drop...DJM offers 3" dropped lower control arms on Summit for $452.39...where as 3" dropped spindles are $229.95....
What about 2 or 2.5" dropped spindles? will that clear a 15" wheel? Thanks for any help guys.
1982 Chevy Silverado C-10 RCLWB - IN PAINT - Inferno Orange Metallic Lowered 4.5/6 - 358 SBC 10.5:1, Comp XE268H cam, Aluminum heads, 650 Double pumper Holley carb, 2400 Holeshot Converter, upgraded T/h350 Trans. Stock Rear end for now (3.08 gear) ![]() 2004 Chevy Silverado 1500 LS RCSWB - Dark Spiral Gray Metallic Lowered 2/4 - 4.8L V8 4L60E 10-bolt. some goodies --- NEW DD 11/9/12 ![]() ![]() "Expect the Un-expected" "Gas, Grass, Or Ass...No one rides for FREE!" ![]() |
#2 | |
It followed me home?
Re: Need some help guys...
Adam That's why they call it a shortcut Kyle, if it was easy it would just be the way. 86 c-10 SWB 85 CCSB 90 GMC K30 Crew SRW 1985 C30 Dually |
Bretzke Racing Inc.
Well the springs i have in it now are stock height with 1 coil chopped off... i think it lowered it about 2" up front...
I wont mind doing some grinding if thats what it comes down for me to do to make my new wheels fit. what about the steering arm part of the dropped spindle? i heard that it rubs either the brake rotor or the tire...? correct me if i'm wrong. This is how it sits with 235/60/r15s...except now it has 4 new BF Goodrich 255/70/r15s...
Go Hard or Go Home!
i have 3" djm drop spindles on my 75. i had to do a little grinding but nothing major. i agree with cochino12 about losing ground clearance with lca's. getting low has its disadvantages, you want to eliminate as many as you can.
75 short wide 350, some mods, scare the piss outta ya quick. 2008 Dodge crew cab. YEAH, it's got a hemi, your ass is going to jail quick. ![]() Some day's, it's just not worth chewing through the restraints................................ |
I've done it both ways and I like the spindle for ground clearanc. However I like the fact that with lca's you can get a little more adjustment on alignment angles. seemed to handle a little better. you will have to grind the control arm from the lower ball joint back about 3 inches or so, but only need to take a half inch of material off(give or take)
6.0 powered square
I have djm 3" coils with hd brakes and I had to grind a little bit on the ears for the calipers but no lower control arm problems but when I had stock steelies on the front the tie rods would rub, when I would turn sharp
Aaron 1980 c-10 short bed lowered, cammed 6.0, 4l80e 3600 stall, smp tune, wilwoods, and flames best time so far best et 7.86 @87 on motor 7.57 90 on a 75 shot Build http://67-72chevytrucks.com/vboard/s...d.php?t=283326 |
