02-18-2009, 02:54 AM | #1 |
quick disc brake question
So I read the sticky about the disc brake swap and I didn't really see what I was looking for. So here's my question. I have a 60 gmc (torsion style) and I've got a bunch of leads on complete front ends (coil spring) is it possible and how hard is it to switch it over?? Thanks alot guys!
02-18-2009, 12:31 PM | #2 |
Re: quick disc brake question
you can just take the hole front cross member out of a 80 1/2 ton trucks and just in stall it in to your truck. remove your old x member and put the newer 1/2 ton x member in you will have to drill some new holes to make it fit. here are some pics of my 60 i did.
vinnie 1960 chevy c10 frame with a 1966 cab 2002 dodge intrepid r/t 2004 chevy 2500 4 door short bed |
02-19-2009, 01:09 AM | #3 |
60-66 Nut
Any 1/2 ton pickup or Suburban front suspension from 1971 to 1987 will bolt in with minor work. I've not done on in a torsion bar truck, but in the '63-'70 trucks you need to drill one hole on each side and elongate one hole on each side.
02-19-2009, 03:00 AM | #4 |
Thanks for the help guys. Im gonna try and buy a 73 front end from a guy that I emailed off of CL and see if he still has it. I'll store it til I can borrow my Dads garage then start tearin stuff off!!
02-20-2009, 12:41 AM | #5 |
so this is probably a no seeing as everyone goes to 5 lug. But is there any one that makes a 6 lug rotor for the 73 set up I'm looking to install?
02-20-2009, 12:44 AM | #6 | |
CHEVY ONLY |
